Is adding sta-bil necessary?
Old Dec 27, 2014 | 11:11 AM
Tommyxgun's Avatar
Tommyxgun
Default Is adding sta-bil necessary?
Car went into storage last week. Fuel was topped off when I parked it, and putting it on the trickle charger today. Car will be in storage for roughly, 3 months. Do I really need to add stabil to the tank? Thanks
Old Dec 27, 2014 | 11:14 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Well it sure wouldn't hurt.
Old Dec 27, 2014 | 11:15 AM
Kenny G's Avatar
Kenny G
Cheap insurance
Old Dec 27, 2014 | 11:17 AM
CQRT's Avatar
CQRT
Probably better done when you filled the tanks . . .while not a necessity- certainly no downside.
Old Dec 27, 2014 | 12:01 PM
Tommyxgun's Avatar
Tommyxgun
Well, the car had a full tank for the past month it hasn't been driven. I added 2 gallons to fill it. Instructions on bottle, also dont say it needed to be put in before a full tank. Just says add and let engine run 5 minutes. Thanks for the insight fellas! The Black Bitch is going to sleep for awhile!!
Old Dec 27, 2014 | 12:10 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've used it for years. There are some that say it isn't necessary, but I always add it anyway. I run my tank down to almost empty and add it at the gas station just before I put it into storage. I usually drive 3-4 miles just to make sure it's throughout the fuel system.
Old Dec 27, 2014 | 12:16 PM
acrace's Avatar
acrace
Like most of the previous posts, it can't hurt.
I use Sta-Bil most years, and I also like to add it when the fuel level is near zero. With the "dual tanks" in the C5s, my logic is that adding it when nearly full means that half the gas isn't treated.
I still make sure that I'm easy on the throttle when pulling my cars out of storage in the spring, until I get the first tankful of fresh gas into the car.
Old Dec 27, 2014 | 12:27 PM
DetroitPlac's Avatar
DetroitPlac
The biggest enemy of gas in storage is condensation. If the tank's full, there's minimal space for condensation to form. Since you're only storing it for 3 months, I say leave it alone since the tank's already full.
Old Dec 27, 2014 | 04:49 PM
Last C5's Avatar
Last C5
It may not be necessary, but I always do it because it's such fun to play with that goofy Stabil bottle.
Old Dec 27, 2014 | 05:30 PM
acrace's Avatar
acrace
That's an excellent point that you make. For many years I stored cars with minimal gas in it, reasoning that I wanted to have as little "old" gas as possible in the tank as possible, come spring time. Then a couple of folks that I really respect told me the same thing as you posted.
Old Dec 27, 2014 | 07:31 PM
1965markaccount's Avatar
1965markaccount
The real problem is with phase separation. The ethanol in the gas will separate with condensation and deposit on the bottom of the tank a sludge that is difficult if not impossible to remove with out cleaning the tanks. This problem comes up a lot with boats where there is a lot of gas and the boat sit for months at a time. My father had an older Christ Craft that we had to pull and completely drain the tanks on. The bottom of the tank was nasty with the phase separation. Additionally the gas will lose about one point of octane for every month it sit out. For the boat we would use high octane over the winter with the thought that the gas should be acceptable when spring came around. Sta-bil is supposed to help prevent both of these issues and for that reason alone I use it every fall when I put my car up for the winter.
Old Dec 27, 2014 | 08:56 PM
I put it in mine each year when I store my car for the winter.
Old Dec 27, 2014 | 10:51 PM
4drturbo's Avatar
4drturbo
I use Seafoam instead.
http://www.bobistheoilguy.com/forums...as_instead_of_
Old Dec 27, 2014 | 11:39 PM
aTeam's Avatar
aTeam
Star Tron Enzyme Fuel Treatment is what I use. I don't put the car away but I add 1oz of the concentrate to every fillup. Apparently it is very good for storage.
Old Dec 28, 2014 | 12:24 AM
jdvann's Avatar
jdvann
I use stabil marine on every fill up, it is counter treatment to the ethanol. Does it work? I don't know but hasn't hurt.
Old Dec 28, 2014 | 10:52 AM
57gman's Avatar
57gman
Originally Posted by Kenny G
Cheap insurance
Let me phrase it another way, why not? $7 bucks. I stored mine for the first time last winter and started and ran perfectly all of last summer.
'97
Old Dec 28, 2014 | 02:35 PM
540i 6spd's Avatar
540i 6spd
For car, yes.
To Is adding sta-bil necessary?
Old Dec 28, 2014 | 03:10 PM
yaknow's Avatar
yaknow
Originally Posted by 4drturbo
me too
Old Dec 28, 2014 | 07:20 PM
o2bnkc's Avatar
o2bnkc
No. Fuel will stay good for 6 months. That's a fact.
Old Dec 28, 2014 | 08:52 PM
Tommyxgun's Avatar
Tommyxgun
Thanks for all the information. I went ahead and put a bottle in. Whether it needed it or not, shes covered...literally!
