Hi all, I'm going to install a stock replacement Dayco Powerbond PB1117N balancer on my stock ls6.
It seems most people are using the ARP bolt/washer in lieu of the stock bolt. Is this setup considered better than using the stock bolt with the GM washer (p/n 12603843)? The GM bolt is washer claims to be diamond embedded to prevent the bolt from backing out.
Stock bolt is still TTY (torque-to-yield) so, one time use - the ARP bolt is reusable. I always replace the stocker with the ARP bolt (P/N 234-2503)whenever I replace a balancer if it's appropriate (my latest balancer came with it's own since it's a non-standard unit). The installation of the ARP is a bit different in that you torque it to a spec after pressing it in to it's proper location. Torque spec with ARP lube is 235 lb. ft. per ARP instructions.
I would go with the reusable ARP bolt and be done with it. Also, pin the balancer while you're in there and never worry about spinning the balancer if you have added, or ever plan to add, power adders (if you do worry, that is).
The ARP bolts are better, but the OEM bolt is also just fine as long as you torque to yield them just one time. I also agree with pinning the balancer to crankshaft. I always just replace the bolt each time.
I would go with the arp bolt... it's reusable and a more straightforward torque process, just torque it and be done... no torquing to 37ft/lbs then trying to stretch it 140 degrees like the stock bolt... I would pin the crank also while you're there, not only will it keep the balancer from spinning on the crank but it will keep the bolt from coming loose
