help removing shift knob!!!!
Old Dec 31, 2014 | 12:58 PM
c5 kabukifox's Avatar
c5 kabukifox
Default help removing shift ****!!!!
So im removing my shifter for a short throw and as i try to get the silver piece outve the **** both tabs break how do i remove this stupid thing now? Im goin at it with a clamp but is there any better/easier way?
Old Dec 31, 2014 | 01:27 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
I'm not sure I understand what u mean by tabs, there are several write ups on changing shift *****, it's a pain in the ars the first time for sure, just don't let it beat you, soak it down with some WD and keep at it, it will come eventually
Good luck ok
Old Dec 31, 2014 | 01:37 PM
frsr06's Avatar
frsr06
http://www.vetteessentials.com/instr...t_install.html
Try this link for directions.
Old Dec 31, 2014 | 01:56 PM
steve8's Avatar
steve8
Vise grips on the key will do the trick.
Old Dec 31, 2014 | 03:27 PM
When I had my 6-speed, I just clamped a pair of vice grips on the top of the key and gently tapped up on the side of the vice grip with a hammer. The key came right out. Depending on where the break in the key is, you may or may not be able to get the vice grip to catch the top of the key. If it won't catch, perhaps a thin flat blade screwdriver would catch and help you get the key loose. Just be careful so as to not damage the leather on the shift ****.
Old Dec 31, 2014 | 05:56 PM
c5 kabukifox
Thanks guys yea i worked on it...well around it it still hasnt come off and i gave up for a bit but in the process of installing the new shifter i dropped a socket in the tunnel....
Old Dec 31, 2014 | 06:03 PM
C5Txfan's Avatar
C5Txfan
Old Dec 31, 2014 | 07:18 PM
jdvann's Avatar
jdvann
This is the instructions I followed...
http://www.conceptualpolymer.com/corvette_install.htm
Old Jan 1, 2015 | 10:36 AM
jackthelad's Avatar
jackthelad
They can be a bear. When I went to change my shifter, I found the key would not come out - tried vise grips, no luck. With the whole unit on the bench, I found that whoever had put it in, had literally splayed out the top part of the shift lever by hammering the key in when it was not properly lined up. Result, shift lever irrevocably jammed in the ****. Sometimes you just need a hacksaw.
To help removing shift knob!!!!
