[Z06] OEM throttle body size?
Old Jan 1, 2015 | 02:35 PM
c5maniac2's Avatar
c5maniac2
Default OEM throttle body size?
For whoever has time please measure your throttle body and tell me what size you come up with. I just measured mine and it is just shy of 4" O.D. Wondering if it's been swapped. I'm making a hard pipe intake for it but having clearance issues. Mines a 2004.
Old Jan 1, 2015 | 04:59 PM
ZZOOM06's Avatar
ZZOOM06
Stock throttle body is 78mm.
Old Jan 1, 2015 | 05:34 PM
c5maniac2's Avatar
c5maniac2
It looks very original, even has the red LS6 tag on top. I guess the measurement is taken at the blade and not the outter opening?
Old Jan 2, 2015 | 03:34 PM
ZZOOM06's Avatar
ZZOOM06
That is correct.
Old Jan 3, 2015 | 05:59 PM
RedZMonte's Avatar
RedZMonte
IIRC the stock throttle body OD is 3.75" and the 78mm is the TB blade size as stated above.
S
Old Jan 4, 2015 | 03:18 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Here is a pic i took comparing the stock LS6 78mm to the LS2 90mm.
Toque
To OEM throttle body size?
