I am pretty sure you can you just need the sensors and someone with a tech 2 programmer but I think once they are added in you cant take them back out i.e. program them out IIRC
Doesn't anyone read the Z06 Faq in the forum? Plenty of info in there. I bought used TPMS monitors, went the local dealer, he fumbled with it awhile but in the end we got them working fine. And zero cost from the dealer.
I didn't see anything in the Z06 FAQs. If it upset you so much. why did you bother to comment?
Not upset, just know when I searching for my Z, I read every bit of that faq more than once. But then I like to be informed before I make a purchase and also know about easy mods....And you obviously skimmed through it cause as posted above, its in there. I will say it didn't go exactly as written in the faq on my '04, but between the Tech and I, we figured it out.
Before Christmas my keyfob receiver stopped responding in the car. It was intermittent when fiddling with it and the plastic cover looked a little melted and the PC board a little off color. I ordered a used replacement for a 2001-2004 corvette from ebay for $65. It worked fine when I installed it and I was able to resync my existing keyfob's. However I started to get the tire pressure sensor warning which I had never received before on the stock Z06. I liked the idea of having TPMS so I lived with it for several months (just need to push reset button on start to clear the message) and then on my recently bought rims and tires I had Titan tire pressure sensors installed ($160 for a set UPC# - 9461564 from titantpms.com). System now works great and gives me tire pressure readings.
