Stupid question, but I need to know
Ok so I have an extremely squeaky pulley (like crazy bad). I have narrowed it down to my a/c pulley. Can I just take my a/c belt off? It is winter time and I can't see myself using A/c until at least April (I'm from alabama).
I also sprayed belt dressing on it and it fixed it for about 15 seconds and then it made it 10x worse. It's the very top AC (idler?) pulley.
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would fix it the correct way because the ac compressor is used in the winter time during defrost cycle.
this video is pretty helpful Corvette pulley ac squeal squeak replace part 2 by froggy - YouTube
Had no clue it was that simple
will do
Having some issues... After watching that video I went to do it myself tonight. While under there and ready to remove the pulley I saw that I have 2 tube like things that are blocking my path to get my socket to the pulley. This is something that the other corvette I saw in the video did not have. And I'm not sure what to do. Here is a pic
When I do the A/C belt on mine I use a wrench to get to that pulley. You can pry a little on the hoses that run there and get a little more room. Or like you said just cut it off and then do the majority of the work when it warms up.
Well I went ahead and removed the AC tensioner. I was able to access the bolt that actually mounts the tensioner, so I removed that and the belt. I then tried and tried to get to that other pulley but I am still unable to get to it. But I was able to touch and spin it to see that it is extremely loose and squeaky, which was my problem.
So I put the main belt back on, and fired up my car, only to notice that my idler pulley (the one in the middle below the intake kinda ) is loose and squeaky as well.
So I have removed that one, and will replace with a new one tomorrow
As for the AC idler, I'm gonna have to buy a longer ratchet, or breaker bar might do it
Received 3,812 Likes
St. Jude Donor '03-'04
AS a point that was touched on, you do not want to disengage your AC compressor completely, especially in an older car.. The AC compressor needs to cycle( through the defrost cycle in the winter ) to keep the oils seals from drying up. Your " Ghetto " fix can cost you, 800 to 1000 dollars.
As I've said here for 14 years.. there is only one right way to fix something..
I couldn't find a idler pulley that fit right. So I repacked my bearings myself in the AC idler and main idler. Now I can't get the AC belt back on
Also now my alternator has gone out. I ordered a Valero regulator to replace it. Hopefully that's what it is. I also took apart my ignition switch and cleaned terminals. Also recharged battery.
