[Z06] Cutting antenna?
Old Aug 11, 2002 | 01:52 AM
TooManyIDs's Avatar
TooManyIDs
Default Re: Cutting antenna? (Tom Steele)
Is it wired for a power antenna, or do you have to run a wire from the head back?....
No, you need power & radio on / off signal. Power can feed off the same source our hard wired radar detectors are using. Radio on / off is picked up at the Bose signal processor (under the dash, above the gas pedal).
See tech tips for details.
