DIY Radiator Screen
Thanks, I'll take a look at that.
because it prevented me from getting the little things, like grass clippings leaves, etc.. the thing that really clog your radiator and AC condenser. I found it to be less than desirable, over all.. will it stop plastic bag? yes ( sometimes ) in my research I've found that running over plastic bags purposely in my tests revealed that the plastic bag stuck to the screen some of the time. So over all a waste of time and money. the small stuff will still get through the screen, the stuff that really clogs things up..
Lots of people on this forum want to do something for the sake of doing something.. want to brag about the cool thing that they have done..
If you use a screen small enough to catch the little stuff it will quickly get clogged and defeat the purpose.
Vendors will make anything they can to make money, because they know how the after market business works. Corvette owners are easy victims of useless products. This doesn't mean that ALL after market products are bad.. I have a ton of after market products that have been fully vetted by me. Im only offering my opinion, and testing, and am man enough to point out the negatives of a well meaning product, that really dose not do what members think it does. if you want to prevent a plastic bag from getting sucked up it will do that.. but.... reaching up to pull a bag out of your AC condenser ( once or twice in a life time, which takes a few seconds ) is much easier then taking off that screen and then putting it back once or twice a year.. removal and reinstallation has to take 20 minutes compared to the 15 seconds it takes to pull a bag.. the screen will not prevent your Ac condenser and Radiator from needing to be cleaned yearly.
I made this screen for less than 5 dollars and ran it for two years... IM happy that it is no longer there..
Bill aka ET
Bill aka ET
there are lots of things that people swear are a good deal... for example this throttle body bypass... its not only a joke, its a waste of time and money...
You can make a throttle body bypass, for less than 3 dollars, yet some vendors will charge you 15 dollars for this useless piece of garbage.. here is why... air flows through the throttle body @ 60 cu feet a second. if the air coming into the throttle body is lets say 100 degreesor less say its 90F.
the engine is running at 190F , the throttle body is 190 F. remove the coolant line and the throttle body will still be 160 F because its passively receiving heat from the intake. the difference in temp with an without the by pass is 30 degrees.. Ambient air is not in the throttle body long enough to change the in coming temperature by even 5 degrees... You would create more available hp by having 5 gallons less ( 30 lbs of fuel ) then using a throttle body bypass... just another useless piece of garbage, that someone could brag about as a modification...
Many of us here have done lots of things and only offer our opinion, and experience based on time, cost , functional worth, etc.. some people have all the money in the world but have no time to do things they want or like to do.. Others have all the time in the world and no money to do it. to some people , the satisfaction of doing something yourself is worth the effort... Some people respect and appreciate other members experiences , Some other member will not. That's why this forum is here, some come for help, some come to offer help, some just come here to share a common interest. However there are also many who come here.. offering bad advice.. and nothing more than 1980's automotive technology.. ill conceived urban legend...The one single most important thing I tell people who come here is to be careful who you listen too.
