Really need C5 help !!
Old Jan 16, 2015 | 03:59 PM
2FAS4UU's Avatar
2FAS4UU
Default Really need C5 help !!
It's that dreaded time of the year for me to get the Vette smogged. I lost a 'Good' friend that made this not a major concern but that has gone away. I was hoping that someone local might have their old 'H' pipe with good cats laying around to either buy or 'rent'. I wish I knew the magic way to fool the computer of the P0420-0430 code. I have a 99' that runs really clean on emissions levels that are well with in Ca. guidelines, but I have the 'check engine' light on (naturally) so it automatically fails. Any help from the forum would be greatly appreciated !!
Old Jan 16, 2015 | 04:23 PM
Phanni's Avatar
Phanni
Surely someone in your area has dismantled a wrecked C-5 and has what you need. If I were you, I'd buy a set and keep them there for those 'trying times'. Check Craig's list and E-bay, you might be surprised what is available.
We have two leaning against the wall here in Knoxville as I type.
Old Jan 16, 2015 | 04:48 PM
Torch Rot Z's Avatar
Torch Rot Z
A "buddy" of mine has the heated cats I believe turned off with HP Tuners. I, I mean "he", has long tubes with off road xpipe and no check engine light on. Texas allows up to 2 "not ready's" during inspection, not sure what your state requires. Now if you have to have the sniffer hooked up, then some spare cats would be needed.
Old Jan 16, 2015 | 06:16 PM
stu12dozen's Avatar
stu12dozen
I have absolutely no idea what a California smog inspection entails, so what worked for me may not suit you.
After installing headers, X-pipe, hi-flow cats and Borla exhaust I had the P0420-0430 codes and the CEL. My tuner deleted the O2 sensors from the program and that solved the problem. No codes, no CEL. Don't know if this is legal in California. Probably not!
Having to re-install the stock exhaust just to pass the smog test is a real PIA!
Old Jan 16, 2015 | 06:39 PM
2FAS4UU's Avatar
2FAS4UU
Thanks for the response, Ca. has the same allowance of two codes as well for 00'-97', but it's the check engine light being on that screws up the whole process. The thing that irks me me about Ca. is my car runs 'Really' clean and exceeds all levels of emissions required to pass, but because the computer says the cats are below efficient levels a stupid light that's on fails it. I guess with new cats my car should show 'No' levels of emissions, I don't know, I'm just P_ _ _ _d about the regulations in Cal.
Old Jan 16, 2015 | 06:44 PM
2FAS4UU's Avatar
2FAS4UU
I feel that I will be looking into that as soon I can locate a tuner in my area. Thanks brother !!
Old Jan 16, 2015 | 07:18 PM
Patches's Avatar
Patches
I have a full set of exhaust manifolds, cats and H-pipe that would work for you that i'm not using and have no plans to use. I work in Irvine - you could come pick them up if I bring them to work. Let me know.
Old Jan 16, 2015 | 08:09 PM
Mitch45's Avatar
Mitch45
remove the light bulb ?
Old Jan 16, 2015 | 08:22 PM
ssrallyred's Avatar
ssrallyred
Only problem with that is the bulb check to see if it comes on is a part of every emissions test for OBDII cars, no matter the state.
Old Jan 16, 2015 | 08:25 PM
ssrallyred's Avatar
ssrallyred
Also OP I don't know if they still sell them because every one that does mods now has a tuner cut off certain things BUT you can see of you can find some O2 simulators. Plug these into the rear O2's connectors and you could have no cats and the light will stay off. About 60 bucks for a pair last time I saw them years ago.
Old Jan 16, 2015 | 08:33 PM
2FAS4UU's Avatar
2FAS4UU
Wow, completely forgot about that possibility. Thanks for the heads up, I will try to see if they are still available. Thank you brother for the suggestion !!
Old Jan 16, 2015 | 08:49 PM
2FAS4UU's Avatar
2FAS4UU
PM sent brother !!
Old Jan 16, 2015 | 10:26 PM
don37's Avatar
don37
Veteran: Canadian Forces
This works great. It generates a .5V signal and holds for a bit, then drops to 0V. And repeats. An astable multivibrator. $20 in parts.... https://www.google.com/search?q=o2+simulator+555+circuit&client =ms-android-motorola&source=lnms&tbm=isch&sa=X&ei=pt W5VLD9Mc61ogTb4oHoAw&ved=0CAYQ_AUoAQ&biw =360&bih=511#imgrc=HHGRbxmQ5EVxyM%253A%3 B_eMTLCJCSTGEvM%3Bhttp%253A%252F%252Fi.y timg.com%252Fvi%252Fa1uIQkdU7QY%252Fmaxr esdefault.jpg%3Bhttp%253A%252F%252Fwww.y outube.com%252Fwatch%253Fv%253Da1uIQkdU7 QY%3B1280%3B720
To Really need C5 help !!
