Storage Bin Covers
Old Jan 19, 2015 | 06:06 PM
tentuna's Avatar
tentuna
Default Storage Bin Covers
I know this is a nit, but on a vert there are three storage bins with covers mine are sagging, I assume they had gotten wet sometime. Has anyone had the same problem in a vert, if so did you replace or is there a way of straightening them out other than that the carpet is in great shape, any suggestions are appreciated.
Old Jan 19, 2015 | 08:12 PM
PhysicsDude55's Avatar
PhysicsDude55
I would try sandwiching them between 2 flat heavy objects (heavy book like a dictionary comes to mind) for a day or 2 and it will probably help.
Mine are a little bit mishapen as well. They're not made out of space-grade materials or anything, so its probably normal for them to lose their shape a bit if you commonly put things on top of them, etc.
Old Jan 19, 2015 | 08:56 PM
You can try what was mentioned, but I have a feeling they will never be like they were originally. You have nothing to lose though. Your best bet would be to see if one of the used parts vendors had a set in good condition that were the same color as the ones you have.
To Storage Bin Covers
