mileage discrepancies
Old Jan 21, 2015 | 08:04 AM
Scott Luttrell's Avatar
Scott Luttrell
Default mileage discrepancies
I'm lookin at a 99 vette. Price is rite but when i got a copy of the car fax it showed the mileage @ 109in 06, 116 in 10, 99 in 9/8/14, 61800 on 12/1/14. Is it that easy to turn back mileage on a 99? How do you tell? Maybe it was a stunt car and got driven backwards a lot. Just curious.
Old Jan 21, 2015 | 08:17 AM
Phanni's Avatar
Phanni
Car Fax reports what is given by the servicing mechanic when service is done. I suspect the head unit of the speedo/Odometer was replaced at some point with a used unit. If the car now has a Heads up display, the 99 was not equipped with the proper connection in the unit so one may have been taken from a newer car equipped with the correct hook up.
I'm guessing on the HUD, but that is one reason why the unit may have been changed.
Old Jan 21, 2015 | 08:39 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Anything you have to explain hurts resale value - simple as that. Doesn't mean you shouldn't buy the car - but I would assume the mileage is much higher than shown and make my offer accordingly. Anyone who buys the car from you down the road will be doing the same...
Old Jan 21, 2015 | 09:23 AM
JR-01's Avatar
JR-01
Is the seller claiming the the mileage on the odometer is correct? I would need an explanation or I would walk.
Old Jan 21, 2015 | 10:31 AM
92GA's Avatar
92GA
Oldtimer
You are wrong about the 99 not having heads up display. They did have heads up display in 99. code UV6
Old Jan 21, 2015 | 11:19 AM
grantv's Avatar
grantv
Default Strange
I was going to ask if it was originally a Canadian car (would be logged in Kilometers here), but the numbers just don't quite add up still; still lower later.
Old Jan 21, 2015 | 11:51 AM
Exactly, my '99 had it and I ordered it in Nov 98 and too delivery in Jan 99.
And I agree with 4XLR8N - I'd have lots of questions about just how many miles are actually on that car. Proceed with caution.
Old Jan 21, 2015 | 11:57 AM
Phanni's Avatar
Phanni
I stand corrected about the HUD.
But the theory about the head unit being replaced still stands. It's likely been replaced for some reason. Unit failure or deceptive marketing are both possibilities.
Old Jan 21, 2015 | 12:37 PM
cessna10's Avatar
cessna10
cesssna10
Old Jan 21, 2015 | 12:43 PM
allred's Avatar
allred
So difficult to remember all the different colors, when which feature was added, etc. Here's the details on the HUD from www.webcars.com.............
"The Heads Up Display (HUD) was available starting in 1999 and was welcomed as a useful driving tool by the 19,034 owners whose Corvettes were so equipped. The system (RPO UV6; $375.00) was rich with features and displayed speedometer, tachometer, (with shift light) water temperature, oil pressure, fuel level and turn signal on the windshield in front of the driver. A flashing "check gauges" indicator would alert the driver that one of the other dashboard alerts needed action. A page feature allowed the driver to view only certain readouts. Adjustment for various driver heights and brightness was available".
As for the OPs speedometer discrepancies, as Phanni states, "Unit failure or deceptive marketing are both possibilities". I would tread lightly.
Old Jan 21, 2015 | 07:07 PM
Scott Luttrell
Default mileage issues
[QUOTE=allred;1588771775]So difficult to remember all the different colors, when which feature was added, etc. Here's the details on the HUD from www.webcars.com.............
Once again thank you all for your time and responses. Gonna leave this one alone. This car also was wrecked. It went to auction on last sale. Don't think a 99 vette with a true 61000 on it is goin to auction. If it were local I'd check it out of curiosity. If it sounds too good walk away. Fast!
Old Jan 21, 2015 | 07:37 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Good call, Scott. Plenty of great C5's out there to be had, no need to settle for something like that one...
Old Jan 21, 2015 | 09:42 PM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
Could be DMV error, If you want send me the vin and I can trace it and figure out why. I work with car titles for a living.
Old Jan 21, 2015 | 10:00 PM
1Willy1's Avatar
1Willy1
Its even easier now to roll back the mileage on a car since everything is digital, all you need is a little plug in computer and the stroke of a key will do it.
On our lexus forums we actually have a vender who will do a roll back for you , but under the legal name which is called "odometer correction" , for $100.00
If the guy doesn't have a proper explanation , like if the car is a Canadian (which has both miles and kilometres), if the head unit has been changed or if the mileage had been changed, id walk away.
Old Jan 21, 2015 | 11:43 PM
Phanni's Avatar
Phanni
The Corvette switches back and forth between miles and Kilos with the push of a button. To change the mileage on one requires more than a hook up to the computer a head unit replacement is the easy way. CarFax records events of service so there is an ongoing record every time one goes through dealership maintenance. Thus if the mileage show a downturn through Carfax, there is usually something going on. Yes dealers can make errors, but they usually don't involve negative 10s of thousands of miles.
Old Jan 21, 2015 | 11:48 PM
1Willy1's Avatar
1Willy1
I wasn't sure if all C5's can switch back and forth between miles and kilometres, I thought it was only Canadian cars but I could be wrong.
That would be my first logical guess, that for whatever reason the mileage was originally registered in kilometres and then later on miles, but if that's not the case then something is up.
Old Jan 22, 2015 | 02:16 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I can switch between miles and kilometers here in the States on my '02 Z06.
It's possible car was brought in for service sometimes with the km showing and sometimes with the miles showing. Easy to switch between the two if you're not careful when checking gauges for examples.
To mileage discrepancies
Old Jan 22, 2015 | 07:03 AM
Scott Luttrell
Hello and thanks for the reply. vin# 1G1YY12G3X5116066 pLEASE LET ME KNOW.NOW I'M REALLY CURIOUS !
Old Jan 22, 2015 | 10:37 AM
JR-01's Avatar
JR-01
Right. C5s have that feature to switch between KM and Miles. Sometimes I switch to KM and have my wife look at the speedo to see how fast I'm going just to freak her out.
Old Jan 22, 2015 | 12:23 PM
tomikem's Avatar
tomikem
If gauge reads 200 mph maximum, it's a U.S. vehicle. If it reads 300 kph maximum, it's a Canadian car.
