z06 headlights
Old Jan 21, 2015 | 07:00 PM
jeffieg's Avatar
jeffieg
Default z06 headlights
can anyone tell me if z06 headlights will work in a 2000 c5 I put a set in I got here and they only come up and will not go down even when lights are off and key out. is the module the same. thanks for any help
Old Jan 21, 2015 | 07:19 PM
momo20's Avatar
momo20
should be the same , I would check your fuses
Old Jan 21, 2015 | 07:53 PM
As far as I know they are the same between the Z06 and the coupe/vert.
Old Jan 21, 2015 | 09:43 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
All C5 headlights are the same.
Please describe what you installed and we may be able to help you out.
Toque
Old Jan 22, 2015 | 05:04 AM
jeffieg's Avatar
jeffieg
Toque
I had the bubble lights in and changed back to flip lights I got from z06. if I unhook ground from batt and reset they come up without being turned on and will not go down. could I have wrong bulbs in and my module think something is wrong from resistance.thanks for help
Old Jan 22, 2015 | 06:36 PM
jeffieg's Avatar
jeffieg
bulbs are fine 9005 for bright and 9006 for dim
Old Jan 22, 2015 | 06:41 PM
Phanni's Avatar
Phanni
Those bulbs aren't HIDs are they?
Old Jan 24, 2015 | 09:22 PM
Toque's Avatar
Toque
I had the exact same issue AFTER I installed my HID bulbs.
This is a normal function of the car. The car wants to tell you that a light(s) is burnt out.
I had to install a resistor pack to fool the car into thinking that I had regular bulbs in there.
My lights would flip up... but NOT come back down.
The old lights you removed..... were they HID ?
Is there a resistor pack in-line from an old HID setup ?
Are your new bulbs HID ?
Toque
Old Jan 25, 2015 | 09:02 AM
jeffieg's Avatar
jeffieg
Toque
the bulbs are factory bulbs I checked them and all the plugs fuses and relays all are good thanks for help
To z06 headlights
