c5 corvette
Old Jan 31, 2015 | 12:08 PM
vettefan84's Avatar
vettefan84
Default c5 corvette
C5,,,,,a pretty girl with a bad f....heart,,,,right now broken at the freeway,,,,overheating problem...no leaks new thermostat clean radiator ..good water pump....this is the hell,,,,,if god exist only he can help me,,,wish me luck these c5's really pissed me off,,,the only good thing is the engine and it beautiful style,,thats it,,,
Old Jan 31, 2015 | 12:16 PM
dannyman's Avatar
dannyman
Sounds like God needs to bleed the air out of the cooling system.
Old Jan 31, 2015 | 12:18 PM
vettefan84's Avatar
vettefan84
Thanks for responding,,,that something that i.like in this forum people respond quickly,,,what do you mean? I have air bubbles in the cooling system??
Old Jan 31, 2015 | 12:20 PM
dannyman's Avatar
dannyman
Try this:
Fill the cooling system through the surge tank.
Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
Start the engine.
Allow the engine to idle for 1 minute.
Install surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
Shut off the engine.
Remove the surge tank cap.
Start the engine.
Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
Install the surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
Rinse away any excess coolant from the engine and the engine compartment.
Inspect the concentration of the engine coolant.
Old Jan 31, 2015 | 12:23 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
That is a possibility. Did you recently have the cooling system opened up?
You didn't give a lot of info to go on...but another possibility is a missing or severely damaged center air dam and/or a front spoiler/splitter that does not allow sufficient air flow. You still need the center air dam even with a spoiler/splitter that allows air flow.
Good luck!
Old Jan 31, 2015 | 12:26 PM
dannyman's Avatar
dannyman
Good luck!
OP said new thermostat, so I'm guessing yes.
Old Jan 31, 2015 | 12:34 PM
vettefan84's Avatar
vettefan84
Good luck!
Yes i recently opened the cooling system,,,because i saw the coolant coming out and i opened the reservoir to check the cap,,,,damn i didnt know that air dam could be so necessary...i bought this car without air dams,,,it cames like this i never took air dam out,,,just came like this,,,,thanks
Old Jan 31, 2015 | 12:39 PM
dannyman's Avatar
dannyman
Post a picture of what you have.. Maybe a full explanation with a bit if history would be beneficial.
If overheating after opening the cooling system then an air lock would be feasible; but if overheating from the time you bought the car then that would be different.
Old Jan 31, 2015 | 12:45 PM
vettefan84's Avatar
vettefan84
It never overheated before,,just now,,,,
Old Jan 31, 2015 | 12:51 PM
dannyman's Avatar
dannyman
Then yes; follow the procedure to eliminate air in the system and you should be good to go!
Repeat until successful.
Old Jan 31, 2015 | 12:54 PM
vettefan84's Avatar
vettefan84
Thanks a lot man,,,,i really apreciate your advice your help...i.m gonna do it as you said,,,just waiting for a friend of mine to bring me the coolant and water..i will as you said thanks one more time
Old Jan 31, 2015 | 12:57 PM
dannyman's Avatar
dannyman
Before signing off cast your vote for a good cause:
https://www.corvetteforum.com/forums...an-2015-a.html
Vote for the C5 question in the poll !!
Old Jan 31, 2015 | 01:40 PM
Besides putting the air dams back in the car, make sure the radiator area, both in front of the radiator and through/behind the radiator is clear from debris. The C5 is a bottom feeder and it acts like a vacuum cleaner going down the road, sucking up leaves, plastic bags, etc. as it goes along.
If any of those areas are clogged, the car will not cool properly and it will overheat.
Old Jan 31, 2015 | 01:46 PM
jdvann's Avatar
jdvann
Danny.. I like your style!
Old Jan 31, 2015 | 01:47 PM
vettefan84's Avatar
vettefan84
Thanks a lot...yes for sure i.m going to install those air dams...radiator is clean,,,now i can see that coolant go back is like going out from reservoir...there is no leaks in any hose or a broken tank...could be the thermostat?? Maybe it is no opening...
Old Jan 31, 2015 | 02:15 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Your comma key is stuck.
Old Jan 31, 2015 | 02:17 PM
vettefan84's Avatar
vettefan84
Lol..what do you mean?
To c5 corvette
