Looking into a 2004 C5
Old Feb 8, 2015 | 12:58 PM
michaelgerson's Avatar
michaelgerson
Default Looking into a 2004 C5
Looking into a 2004 C5. Any particular issues related to this end of series car. Also, what is and and value of "rip shifter" and what is a "crossover bar? I assume most of the bugs have been resolved by 2004.
Old Feb 8, 2015 | 01:30 PM
73Corvette's Avatar
73Corvette
Might check the VIN on that car these are the ones that had crossover/gas tank issues
2004 Chevrolet Corvette
VIN 45110258 to 45125500
Old Feb 8, 2015 | 02:38 PM
PhysicsDude55's Avatar
PhysicsDude55
You are correct that the 2001-2004 C5s are more desirable. They have fewer issues overall, and a little better performance.
I'm not sure what a crossover bar is? There is a "Crossover tube" that connects the 2 gas tanks. Sometimes the crossover tube leaks, and its not an easy repair, so if the crossover tube has been replaced, that would be a plus. Crossover bar might refer to the sway bars or anti-roll bars? Not sure.
Rip Shifter probably means that the shifter has been changed to an aftermarket "B&M Ripper" shifter. I happen to have this shifter in my car, and I do like it. It is a short throw shifter and is generally one of the more aggressive and "notchy" shifters out there. Its more race oriented. If you are looking more for a daily cruiser, you might want to change it out to something more comfortable. Just depends on preference. If/when you drive the car you can see how you like it.
The aftermarket shifter does not add anything to the value of the car, infact some could argue it detracts.
Old Feb 9, 2015 | 12:56 AM
Read the material in this thread too.
https://www.corvetteforum.com/forums...ion-files.html
Old Feb 9, 2015 | 01:08 AM
grantv's Avatar
grantv
Crossover bar possibilities ...
-Strut tower brace?
-H pipe (factory) or X pipe (aftermarket)?
Old Feb 9, 2015 | 10:50 AM
dadaroo's Avatar
dadaroo
Make sure you know how to pull the "onboard" computer(s) DIC trouble codes from the dash. You need to pull and record them and then delete them before you go for a drive. Afterwards pull them again BEFORE you turn the engine OFF. If you don't know how let us know and we can provide you with the info.
Always not if they are H, C, or H and C. Meaning History or Current
Old Feb 10, 2015 | 06:34 AM
Cybermind's Avatar
Cybermind
Usually, the end-of-series cars are always the best. In this case, you need to be careful. 2004 was the first year that GM decided to phase-in some C6 tech such as relocating the fuel filter within the gas tank. But all in all, apart from the cracked fuel crossover pipes (on top of engine), there shouldn't be any major issues to look out for.
Old Feb 10, 2015 | 06:38 AM
michaelgerson
Default Pull trouble codes
Why do you have to pull codes every time you,drive the car. What is going on with the car. Never heard of having to do this.
Old Feb 10, 2015 | 07:25 AM
rjwz28's Avatar
rjwz28
You don't have to do it every time, but it is recommended the first time; that way you will know if the car is having issues. Once you clear the codes, you could check them every once in a while to make sure that everything is working properly. You've never heard of people doing this because this feature is unusual; most vehicles require a tool to read the codes.
Old Feb 10, 2015 | 08:15 AM
dadaroo's Avatar
dadaroo
My guidance was intended for use when you inspect any C5, not a daily routine.
Old Feb 10, 2015 | 08:43 AM
michaelgerson
Got it. Thanks.
Old Feb 10, 2015 | 08:55 AM
michaelgerson
Default Thanks
Thanks to all for your input. In the meantime, I came across another 2004 Torch Red convertible at a major LA dealer. Checked the vin and numbers not in the range of concern for the fuel crossover issue. They had the complete Car Fax with ALL service history. 40,000 miles at $20K. New Michiline sport RFs. All original garage queen traded in for C7z51. Fresh Mobile 1 and full tank of 91. Detailed to car show quality. I swear, the engine compartment was cleaner than new. Thnk I'll pull the plug today. I have a 2011 Torch Red Coupe. Am I crazy to put a 2004 Torch Red Convertible next to it. Can you own too many Vettes?
Old Feb 10, 2015 | 09:02 AM
73Corvette's Avatar
73Corvette
Cross over fill tube
Old Feb 10, 2015 | 09:05 AM
73Corvette's Avatar
73Corvette
Absolutely NOT... see if the dealership will trade you Run Flats for NON Run Flats as part of the deal... it will save you having to do it later.
The Run Flats are very noisy.. clickity clack clickity clack
Good luck can't wait to see it, auto or manual?
Old Feb 11, 2015 | 03:14 PM
rjwz28's Avatar
rjwz28
They might actually be good to go if they're Super Sports... Pilot Super Sport ZPs are not the Goodyear EMTs these cars came with
I'd drive it before I make that call
I just won't run them because they're stiffer and heavier than I want, but I probably have different goals with my car than a guy buying a vert
Old Feb 11, 2015 | 04:47 PM
michaelgerson
The tires are super sports. I believe in RFs. Got a sidewall puncture on my C 6 OEM Goodyears in the winding hlls above Malibu. No way did I want to pump goo in and try to add air or wait for a flatbed. Had 28k miles so was time for new tires. Got Firestone Firehawk RFs. Car runs great and no road noise. Non RFs may be better, but not worth the risk to me. Thanks for all the good feedback. Love the wealth of info on the Forum.
Old Feb 12, 2015 | 11:22 AM
SG Lou's Avatar
SG Lou
Good Luck ! I got a Torch Red 04 A6 Coupe and i just LOVE IT !
To Looking into a 2004 C5
