Bye Bye BSM's
Old Feb 10, 2015 | 10:03 PM
elbaite's Avatar
elbaite
Default Bye Bye BSM's
Old Feb 10, 2015 | 10:15 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Well done! Looks great!
Old Feb 10, 2015 | 10:18 PM
PitbullRescuer's Avatar
PitbullRescuer
Does look good. What did you use to remove the left over glue? And did it leave any shadows in the paint from being on there?
Old Feb 10, 2015 | 10:24 PM
JaxEagle's Avatar
JaxEagle
Nicely done and it looks fantastic. Smoooooooth!
Old Feb 10, 2015 | 10:27 PM
Barndog Buddha's Avatar
Barndog Buddha
From: Gurnee IL. so close to Wisc. I can smell it when they cut the cheese
Looks great, good job
Old Feb 10, 2015 | 10:28 PM
fuelspill's Avatar
fuelspill
Looks great. What did you remove the glue with. Ived used the rubber wheel before in a drill to remove glue from a metal fender but haven't tried it on a glass fender.
Old Feb 10, 2015 | 10:58 PM
elbaite's Avatar
elbaite
1st side I used Goo Gone and fingernails (wore my nails down to the fingertips). 2nd side I put the Goo Gone away and heated a few inches at a time with the hair dryer and peeled the softened glue with my fingers.
One 3" area with a bit of shading - rubbed it with Quixx Scratch Remover (rubbing compound and polish - didn't use the 3000 sandpaper) - did the trick.
A note: Any grit lodged in the crack between BSM and body is sure to scratch the clear coat as you heat the tape and saw through it with the fishing line (mine did some on the driver side - almost none on the passenger side). The scratches were shallow and cleaned up well with the two stage Quixx Scratch Remover (and lots and lots of rubbing with the compound - no sanding).
Old Feb 10, 2015 | 11:07 PM
allred's Avatar
allred
Wonderful post, and encouragement for others who may be daunted about removing their BSMs.
I know there are separate schools of opinion regarding BSMs, I don't have them on my Torch Red coupe, but I have to admit that on certain colors I think they compliment. I particularly like them on Pewter C5s..........................but only my opinion and I don't want to start a pro-anti BSM thread here.
Old Feb 10, 2015 | 11:20 PM
brplatz's Avatar
brplatz
Looks great! I did mine about a month or so ago. Very similar setup, but I used a heat gun, which really got things moving. I also rubbed my fingernails down like crazy.
A polisher and some swirl remover is all it took to look perfect.
Old Feb 10, 2015 | 11:31 PM
73Corvette's Avatar
73Corvette
Good work..
Old Feb 10, 2015 | 11:46 PM
akn224's Avatar
akn224
Looks great! I can't wait to remove mine
Old Feb 11, 2015 | 12:18 AM
While I like the look of BSMs on the cars, yours looks very good without them. Nice job getting them off.
Old Feb 11, 2015 | 07:36 AM
Cybermind's Avatar
Cybermind
Congratulations and welcome to the club. I did mine last fall and couldn't be happier. Once they're off, you realize what beautiful curves our cars have. Mine came off without too much trouble. I used fishing line and WD40. Then finished everything off with Bug/Tar remover and a final coat of TurtleWax Ice.
Old Feb 11, 2015 | 08:49 AM
bjones7131's Avatar
bjones7131
Looks good on a job well done but for me, I will be keeping mine.
Old Feb 11, 2015 | 11:17 AM
SG Lou's Avatar
SG Lou
I did mine a few yrs ago and I never regretted it !
Old Feb 11, 2015 | 12:05 PM
Koufax's Avatar
Koufax
I'm with Vetteman Jack on this one. I like my BSMs, but the car looks great without them. I always enjoy seeing someone's mod and learning how he did it. Great work!
Old Feb 11, 2015 | 02:33 PM
cmjuhl's Avatar
cmjuhl
To Bye Bye BSM's
Old Feb 11, 2015 | 08:55 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Nice job.
Mine are still on, other things bug me more!
Old Feb 12, 2015 | 01:20 AM
VETJAZZ's Avatar
VETJAZZ
Job well done!
Old Feb 12, 2015 | 01:29 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Well done!
