spark plug boot protectors?
Old Apr 23, 2017 | 06:47 PM
99blue frc's Avatar
99blue frc
not to hijack the thread but do you remove the boot from off the wire then install the sock? I tried to install one today but it would not go over the coil boot. I got mine from ebay and they have a metal ring on the coil side of the sock
Old Apr 23, 2017 | 07:17 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
As you can see from this picture, the red heat sleeves slip over the coil boots of the Taylor Thundervolt wires. I have since replaced my red heat protection sleeves with longer Black sleeves. They slipped on easily. You should unplug the wire from the plug and slip them on that way.
Old Apr 23, 2017 | 07:37 PM
99blue frc's Avatar
99blue frc
mike , I have the gm red performance wires . I don't believe that the socks will go over the spark plug boot. I may just have to get better socks.
Old Apr 23, 2017 | 07:39 PM
edram454's Avatar
edram454
got them on my z06 with kooks long tube headers. good insurance.
Old Apr 24, 2017 | 03:06 AM
DetroitPlac's Avatar
DetroitPlac
Depends on the socks. I have GM red wires and the socks I bought (also from eBay) fit perfectly. Can just disconnect the wire at the coil and slide the sock on.
Old Apr 24, 2017 | 10:20 AM
photonhunter's Avatar
photonhunter
..... I tried to install one today but it would not go over the coil boot. I got mine from ebay and they have a metal ring on the coil side of the sock
I've seen some people use their nippers to split the wire ring to gain enough of an opening.
dan k.
Old Apr 24, 2017 | 04:16 PM
99blue frc's Avatar
99blue frc
photonhunter, I think I will try to split the ring in the sock and see what happens.
