dic replacement
Old Feb 16, 2015 | 01:43 PM
Scott Luttrell's Avatar
Scott Luttrell
Default dic replacement
Gettin ready to replace the dic unit in my 99. 1- how do i tell the unit is good? 2- on the heater/ ac there is no display . Can i fix this while i have the dash apart? if not , whats the fix. settin em up and knockin em down!! Next : Oil sending unit ! BTW Thanks again to Vetteman Jack!
Old Feb 16, 2015 | 02:01 PM
knewblewkorvette's Avatar
knewblewkorvette
As for the AC display:
https://www.corvetteforum.com/forums...splay-fix.html
and if you can't do it here is a guy that does:
http://davescorvetteilluminations.com/PRICES.html
Old Feb 16, 2015 | 10:44 PM
You're welcome, Scott. Hope the files I sent you help you with the OPS replacement.
Old Feb 17, 2015 | 07:48 AM
Scott Luttrell
Default HVAC screen brightness
Hi, thanks for the knowledge. I'll do it while i'm replacing the dic buttons. Just noticed the gas gauge is a little off. what do you think? sea foam, marvel?
Old Feb 17, 2015 | 08:05 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Gas gauge = Techron. I usually add a bottle in the spring.
Old Feb 17, 2015 | 03:54 PM
knewblewkorvette
I swear by the stuff, it truely works. Might take a couple of bottles but it fixed my gas gauge problem.
To dic replacement
