Fix Service Active Handling - Code C1287
Old Feb 22, 2015 | 08:00 PM
UM Rebel's Avatar
UM Rebel
Default Fix Service Active Handling - Code C1287
I've been getting Service Active Handling message with Code C1287 - Steering Sensor Rate Malfunction. It would usually come on pretty soon after even a short drive. I tried unplugging and replugging connection at steering wheel speed sensor a few times with no success. A few days ago I decided to unplug connection and sprayed CRC cleaner on connections and all around the sensor. Since then no message or code. I'm hoping that was a fix without replacing sensor. Guess time will tell.
Old Feb 22, 2015 | 08:08 PM
73Corvette's Avatar
73Corvette
way to go... and thank you for sharing. guys like you make it much less stressful to own a C5!
Old Feb 22, 2015 | 08:23 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Wish my 01 was that easy I have the intermittent c1214 code and have sprayed the EBCM connections before with no luck
To Fix Service Active Handling - Code C1287
