C7 Wheels on C5 Base model
Old Feb 23, 2015 | 07:33 PM
Mastersorbet's Avatar
Mastersorbet
Default C7 Wheels on C5 Base model
Hi everyone
I'm starting a new thread to provide some information and share my experience with c7 wheels.
Long story short, I was on the market for a new set of wheels and found a killer deal on c7 wheels with OEM tire that only had 5K miles. So here is what I had to do:
The front wheels fit the car perfect. They stick out about .200" further than the OEM wheels, but they are still inside the wheel well. The rears require a 3/4" to a 1" spacers. I ordered 1" spacers since they were easier to find and the entire package sits about 1/8" pass the fender. To me it still looks good but a 3/4" spacer may work better for anyone looking to keep the wheels inside. Look at the pic below for a better reference. I hope this helps.
I think the car hasn't settled in yet and I'm not driving it in this weather.
Rear With 1" spacer
Front. Look at all the clearance between the wheel and the break caliper.
Old Feb 23, 2015 | 07:44 PM
blackmachdown's Avatar
blackmachdown
Surprisingly, that doesn't look too bad!
Old Feb 23, 2015 | 08:50 PM
Anthraxmm's Avatar
Anthraxmm
looks good i like it.
Old Feb 23, 2015 | 08:59 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Nothing wrong with a killer deal! And they look good!
Old Feb 23, 2015 | 09:10 PM
speedmaster64's Avatar
speedmaster64
I'm just not feeling the silver on silver, somehow. If they were gun metal grey they would look fantastic.
Old Feb 23, 2015 | 09:15 PM
Mastersorbet
I like the silver on silver, but I agree with you with the gun metal, that would look fantastic. On the second hand, to me it looks better than black c6 replicas
Old Feb 23, 2015 | 09:24 PM
RedC5's Avatar
RedC5
Sidebar question - will C5 tires and wheels work in a base C7 nonz51? I have winter tires and if I ever get a C7 will the fronts clear the calipers being 17"? Photos show maybe enough clearance but not sure.....
Old Feb 23, 2015 | 11:18 PM
Looks pretty good.
Old Feb 24, 2015 | 08:30 AM
Sterling04's Avatar
Sterling04
What length studs did you have to use with the spacers and where did you get them?
Old Feb 24, 2015 | 08:52 AM
Koufax's Avatar
Koufax
I think it looks great. Nice job and thanks for posting this information.
Old Feb 24, 2015 | 11:48 AM
2FAS4UU's Avatar
2FAS4UU
Just looking at your pics (#4) and assuming that maybe your project is still not completed. Reason being the obvious, you are needing to paint the spacer and all the rotor caps to blend visually. Jus' say'n !! The wheels look good.
Old Feb 24, 2015 | 05:17 PM
CQRT's Avatar
CQRT
Old Feb 24, 2015 | 09:40 PM
Mastersorbet
I'm using the OEM studs. It worked fine. I may have an issue when I switch to 20mm spacers. I have a grinder for that.
Old Feb 24, 2015 | 09:43 PM
Mastersorbet
Yes, your assumption is on the right track. I'm not feeling the way the wheels are sticking out so I ordered 20mm spacers (.780" thick). The spacers I ordered are anodized black so it will look a lot better.
Old Feb 27, 2015 | 12:12 AM
Mastersorbet
Here is an update. I replaced the rear 1" spacers with 3/4 and it works a lot better. Pics do no justice. I had to shorten the wheelstuds but That did not affect the grip.
Old Feb 27, 2015 | 08:34 AM
73Corvette's Avatar
73Corvette
Those look great... glad you blacked out the rotors, makes them sorta disappear. Nice!
Old Feb 27, 2015 | 09:32 AM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
While I'm not planning to make this change, I think its great that you share this with the forum members, thanks.
To C7 Wheels on C5 Base model
Old Feb 27, 2015 | 09:47 AM
tommie's Avatar
tommie
saw this on FB the other day. thanks for sharing!
Old Feb 27, 2015 | 10:08 AM
envyz06's Avatar
envyz06
They look pretty good actually!
Old Feb 27, 2015 | 03:11 PM
B747VET's Avatar
B747VET
I think they look great on your car! But, those C7 caps absolutely have to go.
