seat beat warning lite
Old Feb 24, 2015 | 04:14 PM
sixbytwo's Avatar
sixbytwo
Default seat beat warning lite
the warning lite stays on once buckled in. I can jam it in a bunch
of times and the lite will flicker but never go out.....your thoughts>>
Old Feb 25, 2015 | 08:52 AM
dadaroo's Avatar
dadaroo
The receiver has a switch in it which is normally closed until the buckle is inserted and it then is opened. This allows the light to be lit if the buckle is not inserted.
Not sure if the switch is a serviceable part or if you have get buy an assembly.
You can disconnect the receiver/switch wiring connector and that will eliminate the light.
Marc at VetteNuts.com might help you with a replacement harness portion.
