rear corvette letters
Old Feb 24, 2015 | 05:44 PM
1999C5JSS's Avatar
1999C5JSS
Default rear corvette letters
Hi Gents
new to C5 and have a question.
my car at the rear has some silly aftermarket carbon C0RVETTE lettering. which I like to remove and go back oem
question is
1- was there a oem black letters that went there?
2- or was there nothing at all from factory?
if there was from GM does anyone have part number that can share for me
Old Feb 24, 2015 | 05:46 PM
73Corvette's Avatar
73Corvette
Nothing...warm the letters up with a hair dryer and gently peel them out..then you can clean up whats left with WD-40, goo be gone, baby oil...just don't use anything that will hurt your paint...acetone, paint thinner etc.
Then you'll be back to stock.
coia96vette's Avatar
coia96vette
Only came with the corvette indent from the factory. No lettering at all.
Old Feb 24, 2015 | 06:38 PM
dbarrym's Avatar
dbarrym
Another option is to use thin monofilament fishing line, a piece 8-10" long with both ends tied to a key ring or other shape you can hold on to easily. Heat the letters up (carefully with a hair dryer or better, leave in direct bright sun if possible) and use a thin piece of wood or a soft plastic tool (don't use anything that can scratch the paint!) to raise a letter edge, then work in the line and use a 'sawing' motion to cut through the adhesive tape. then clean the residue up as mentioned above, wash and polish, and admire.
Barry
Old Feb 24, 2015 | 06:42 PM
1999C5JSS's Avatar
1999C5JSS
great thanks guys will do so tonight
Old Feb 24, 2015 | 06:47 PM
StripedZebra's Avatar
StripedZebra
I think they look good in that pic, but to each their own.
Old Feb 24, 2015 | 09:20 PM
yanmar's Avatar
yanmar
Default Rear corvette letters
THE EASIEST,QUICKEST, AND SAFEST WAY TO REMOVE THE LETTERS IS WITH 3M ADHESIVE REMOVER.
Old Feb 24, 2015 | 10:58 PM
Yes, easy to remove and several methods have been suggested. Good luck.
To rear corvette letters
