Need opinion
Old Mar 2, 2015 | 10:21 PM
73ls1's Avatar
73ls1
Default Need opinion
I have a 73 but I am going to buy a c5. I found a 98 coupe with 22,000 miles and a 2004 coupe with 76,000 miles. I like the 22,000 miles on the 98 but I have been told you can't get abs controllers if they go bad. The price on the 04 is $17;000 and the 98 is $14;500.
What is your opinion? Thanks Charlie
Old Mar 2, 2015 | 10:28 PM
StingrayRebel's Avatar
StingrayRebel
I would go with the newer one for the reason you mentioned, I believe there are other nuances about the older models too but I'm not as familiar with them as the 01+... 76k is still not bad mileage, maybe you could talk them down a bit and close the money gap between the older car
Old Mar 2, 2015 | 10:32 PM
That's a lot of difference in miles, but the 2004 has many more very good updates to the platform. Hard call, but if the '04 checked out 100%, I'd probably lean towards it.
Old Mar 2, 2015 | 10:36 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
When I shopped for mine I was told "buy as new as you can afford".
Found an 02 with 1,900 miles.
Good Luck!!
Old Mar 2, 2015 | 10:42 PM
73ls1's Avatar
73ls1
The 04 is in Ohio. As soon as the weather is better I will take a look at it.At 76000 miles what can I look for?
Old Mar 2, 2015 | 11:42 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
This should cover most of your questions:
https://www.corvetteforum.com/forums...ion-files.html
Old Mar 3, 2015 | 06:55 AM
Fcar 98's Avatar
Fcar 98
Yes the abs in the 98 May be a problem. Check to see if it has AH, that seems to be a factor with the abs unit. The 01 thru 04 have some problems that the 98 does not. So none of these car are full proof. Any used car is a gamble. As an owner of a 98 and has friends that own 98's a lot of these problems that are discussed have not appeared in these cars. One has 28000 miles mine has 45000 and one has over 80000 miles. The final pick is yours. 22000 miles is very low, still a new car. Just my 2 cents. Good luck with your pick
Old Mar 3, 2015 | 07:21 AM
Phanni's Avatar
Phanni
I'd go with the newer 2004, there are several differences that can become costly with the older model. EBCM, TPMS, remote key fobs etc. The newer car has 5 more HP also. The 2004 did have some issues with the fuel tank crossover leaking, but a recall is supposed to have fixed that. 75,000 miles on a LS engine is just nicely broken in.
Old Mar 3, 2015 | 07:24 AM
dadaroo's Avatar
dadaroo
Recommend for the 2004 you determine if the VIN is in the range for a fuel tank problem. There was a recall that may or may not have been done if the VIN is in the range. NOT A CHEAP FIX.
https://www.corvetteforum.com/forums...el-system.html
Old Mar 3, 2015 | 07:31 AM
black match box's Avatar
black match box
The 04.
Old Mar 3, 2015 | 10:03 AM
allred's Avatar
allred
Don't buy either, look for a 2002/2003/2004 with low miles, there are plenty around.
Old Mar 3, 2015 | 10:08 AM
CQRT's Avatar
CQRT
I followed a similar path and sold my `73 in early October - - bought the `02 C5 in November -(a couple years ago) - -From your two options, I'd go for the `04 in Ohio . . . not a bad price point to start from.
Old Mar 3, 2015 | 10:32 AM
DRAFT1's Avatar
DRAFT1
Don't narrow it down to two. I shopped for months and flew 700 miles to buy mine. It was worth the wait, even after the plane ticket. Take your time with this and good luck.
Old Mar 3, 2015 | 12:04 PM
Corvette#2's Avatar
Corvette#2
So cars with AH are more likely to have issues with the abs unit ? My car doesn't have AH. I was happy with that, I figured one less thing to go wrong.
OP, hard decision. Colors and options would be a large factor in my decision. But just based on what you told us, I lean towards the '98 with 22k miles.
I bought a 2000 with 45k miles. I test drove an 01 and 03. I could feel the extra torque, but ultimately decided I wanted the closest thing to a new car.
Not that 76000 is high mileage, but 22000 is really low. But this is where options come into play. I'd rather have a mag red 6 speed with 76k miles than a green automatic with 22k miles. Or a car with lots of records than a garage queen that has been sitting for years.
Old Mar 3, 2015 | 04:36 PM
cessna10's Avatar
cessna10
cesssna10
You nailed it, for 17k to 18k you should be able to get
an 03 or 04 with under 40,000 miles
Old Mar 3, 2015 | 05:05 PM
jjaaam's Avatar
jjaaam
Personally I would go for the '04. Yes, the mileage is higher, but I've heard of many issues with the older models, parts availabilty being one of them.
Like many have said already, though, I would check the VIN range to make sure you don't have one with the defective gas tank issues.
Properly taken care of these things will last 200,000 and more...
Old Mar 3, 2015 | 05:07 PM
jjaaam's Avatar
jjaaam
Not to hijack the thread (sorry OP), but it was a recall isn't GM obligated to fix the issue? Or was there a time range where the recall expired?
Old Mar 3, 2015 | 10:24 PM
CaliforniaJack's Avatar
CaliforniaJack
Default Learning curve
As a longtime Engineer and a 2000 C5 owner, I'm convinced that it takes GM at least four years into a new model until most of the bugs get sorted out. I waited until the fourth year of the C5 to order mine and I wish I'd waited longer. Don't consider anything earlier than 2001!
Old Mar 3, 2015 | 10:33 PM
73ls1's Avatar
73ls1
Thanks everybody for your comments. I think I will take my time and look for a 03 or 04 red coupe. Charlie
To Need opinion
