I have a stock 2001 Z06, I want to run Fikse Fm/5 18x9.5 on the front and 18x10.5 wheels on the back. I need to order new tires and thought I'd get 265 / 20 / 18 front and 295 / 35 / 18's on the back. Will the rims fit on those tire? Or I guess a better question is will 265/40/18's fit on the front of my Z? I have no idea and don't want to order something that won't work.
Laurie
265/35/18 is almost exactly the same size as the stock 265/40/17 and will work perrfectly up front. The 265/40/18 is almost an inch taller, is taller than the rear, and will screw up your active handling.
