telescopic steering wheel help
Old Mar 12, 2015 | 05:13 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Default telescopic steering wheel help
A little help guys, the other day my telescopic steering wheel stopped working. I haven't noticed anything else not working, so I thought I would do a little trouble shooting. Checked the fuse box and the manual,don't see anything for the steering wheel. Any suggestions and help would be great,thanks. L8R ZFLASH
Old Mar 12, 2015 | 05:17 PM
Patches's Avatar
Patches
Do this:
Telescoping Steering Column Calibration
Telescoping Soft Stops
After replacement of the seat control module, it is necessary to program the telescoping soft stops. Each soft stop is a programmable end of travel that is set approximately 1.3 cm (0.5 inch) from the mechanical end of travel. The steering column has a soft stop set at each end of the telescoping in/out movement. The system uses soft stops to prevent wear on the system by ensuring that the steering column movement stops before it reaches its mechanical end of travel in any direction. The soft stops are initially programmed at the factory. The stop positions may be reprogrammed, which is necessary any time the seat control module is replaced, as described in the following procedure.
Telescoping Soft Stop Programming Procedure
1] Turn ignition to ON, leaving the engine off.
2] To set the telescoping in soft stop, press the telescoping COLUMN IN switch at least eight times or until the column moves.
3] Press the telescoping COLUMN IN switch and hold the switch until the column travels all the way in, and continue to hold the switch about a second after motion stops at the mechanical end of travel. The soft stop for the column in position is now set. The seat control module automatically goes back to the normal mode of operation.
4] Repeat steps 2 and 3, using the COLUMN OUT switch, to set the column out position soft stop
Old Mar 12, 2015 | 06:05 PM
ZFLASH's Avatar
ZFLASH
D*mn Patches that was quick,and may I say,your the man. That took care of it,I don't know why it happened because I haven't replaced the seat module. Now I did unplug the seat and removed it to install new seat skins last summer,maybe that was it. But for it to take that long is a mystery to me,but anyway,thanks again. L8R ZFLASH
Old Mar 13, 2015 | 01:06 PM
3sACROWD's Avatar
3sACROWD
You may want to check the connectors under the seat to verify one isn't loose otherwise it may do it again.
To telescopic steering wheel help
