TT setup on ls1
Old Mar 16, 2015 | 10:15 AM
C5_Finatic2000's Avatar
C5_Finatic2000
Default TT setup on ls1
I have a 2000 vette that I'm putting another ls1 in....it's got an ms3 cam, PAC dual springs, ls7 lifters, LS2 chain, brand new ported and polished heads, 5 angle valve job, high volume oil pump.....I'm pretty sure it still has flattop pistons and new I beams but is there anything else I need to do to the motor before I go and buy the TT kit and have someone install it?
Old Mar 16, 2015 | 12:28 PM
IMXCITD's Avatar
IMXCITD
just take a look at your overall plan as you will prob want to consider: clutch, injectors, fuel pump, alky/meth, and tune. Good luck!
Old Mar 16, 2015 | 12:33 PM
C5_Finatic2000
Already planned alot just need to kno if I needed to do anything else to the motor before I start bolting stuff on....I've already got the trans rebuilt and the rear end is new 3.42
To TT setup on ls1
