trany pan deep or shallow
Old Mar 17, 2015 | 10:29 PM
Fast Red's Avatar
Fast Red
Default trany pan deep or shallow
Does anyone know on a 98 stock corvette, what tranny pan, deep or shallow comes on it. Is there any way to tell before I tear into it. I ordered a deep filter but now Im not sure.
Old Mar 18, 2015 | 12:02 AM
striper's Avatar
striper
I had a '98 with an auto. When I changed the fluid it was a shallow pan. A deep pan would noticeably hang down between the exhaust pipes if you had one. Probably at least 4" deep or more.
Old Mar 18, 2015 | 12:44 PM
Fast Red's Avatar
Fast Red
Originally Posted by Fast Red
Does anyone know on a 98 stock vette, what tranny pan, deep or shallow comes on it. Is there any way to tell before I tear into it. I ordered a deep filter but now Im not sure.
Called the dealer because no one really knows. Guess what the dealer cant even tell me. If it is a shallow pan 2 & 11/32 deep so I have to drive it over the pit and check it first. I think the parts place ordered a deep one but am thinking it is probably a shallow. Manual states 10.5 capacity and 5 quarts with a filter. Now that should tell the dealer which pan it is by the capacity. So out to waste some time checking before I tear into it. I want it hot to drain and refill. About 108 degrees.
Old Mar 18, 2015 | 03:38 PM
Cutlassmaster's Avatar
Cutlassmaster
On my 99, I thought it was deep because the filter had an extra tube going down into the bump in the pan. When i did mine i bought one from the dealer and they ordered it. It fit no problems but as i said, had the tube on the bottom of the filter. When in doubt, buy 1 of each and return unused one.
Chris
Old Mar 22, 2015 | 04:05 PM
Fast Red's Avatar
Fast Red
Default What I found out on tranny filter.....
It did take the deep pan filter. The pan measured as a shallow on from the exterior but go figure. It doesn't hang down lower. I guess at the deep filter and got an AC Delco. The pan was cleaner than any other tranny pan I have pulled. Even the fluid looked good. I was able to put a little less than 5 quarts back into it. Can any one tell me what the date coding is on the old filter? It has ( 13 07 ) stamped on it. Since I have a 98 vette , it could be the original or could be a new one made in 2013 seventh month. ????? just wondering if it was changed.
To trany pan deep or shallow
