Horn doesn't work
Old Mar 21, 2015 | 09:48 AM
Rans's Avatar
Rans
Cruising
Default Horn doesn't work
My horn doesn't work from the steering wheel, but works when I lock the doors from the remote. What should I check?
Old Mar 21, 2015 | 11:05 AM
dadaroo's Avatar
dadaroo
Most likely it is the membrane in the steering wheel, a common issue. Here is the schematic. Not at home with the info on how to check it out. Let us know how you want to proceed. I doubt it is in the wiring but once you access it you can verify.
Since the FOB can make the horn work it has to be an issue in the circuit going to the fuse box.
Old Mar 21, 2015 | 11:07 AM
jdvann's Avatar
jdvann
Most likely the horn membrane on the steering wheel...this is what I did. If your research in the circuits points to the membrane then this is how you fix it.
Old Mar 21, 2015 | 12:26 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
That looks much easier then taking the steering wheel off like in the older days.....
Old Mar 21, 2015 | 02:30 PM
Rans's Avatar
Rans
Cruising
Old Mar 21, 2015 | 02:43 PM
Rans's Avatar
Rans
Cruising
It is not getting voltage to the relay when the horn is pressed. I will get a new membrane later and replace it.
Thanks a million for the information....It was a great help.
To Horn doesn't work
