Excessive Oil use
Old Mar 23, 2015 | 12:47 PM
Drumzy's Avatar
Drumzy
Default Excessive Oil use
Just bought an 01 back in Oct. and after 3000 miles it's a quart low. I heard GM was replacing or rebuilding the engine on 01 models if you complained of oil burning. Being the car is 14 yrs old but only has 19,000 miles....does anyone know if GM will still rebuild or replace the engine?
Old Mar 23, 2015 | 12:51 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
You can call a Chevy dealership or GM directly if you can find the right number but I doubt it. Too much time has elapsed.
Old Mar 23, 2015 | 01:08 PM
Corvette#2's Avatar
Corvette#2
A quart every 3,000 miles is not bad at all.
Even if it were in warranty, I don't think that's bad enough they would rebuild it. I think the engines getting warranty rebuilds were burning a lot more, like a quart every 1,000 or less.
Old Mar 23, 2015 | 01:21 PM
Chicago1's Avatar
Chicago1
They did but that was back in the day it would be out of pocket now from my understanding. I have a 01 and it does the same probably more now that I think about it. Even worse since I put the blower on but it does have 100k on it but I didn't buy mine to wax it.
Old Mar 23, 2015 | 01:43 PM
El original's Avatar
El original
That consumption is well within "acceptable" with GM...just add a quart or change oil when you need to add a quart.
Old Mar 23, 2015 | 01:46 PM
eevette2001's Avatar
eevette2001
1 qt/1000 miles is consider acceptable by most manufacturers. Pretty sure the service manager wherever you take it will have a good laugh. 1qt/3000 miles they won't even listen to what your saying.
Put a catch can on it and put the oil it collects back in if your concerned about losing it. I barely put 3K miles a year on mine.
Old Mar 23, 2015 | 02:03 PM
JR-01's Avatar
JR-01
Mine used oil when I bought it. Switched to Mobil1 High Mileage and now it did not use a drop of oil in 6000 miles.
Old Mar 23, 2015 | 02:04 PM
Drumzy's Avatar
Drumzy
No drips underneath the car. My other cars never used oil like this....I'd go 5 - 6k between oil changes and they were never 1 qt low.
Old Mar 23, 2015 | 06:02 PM
Chances of getting GM to do anything to a 14 year old car are slim to none IMO. I had a '00 coupe that had the excessive oil consumption problem - was eating a quart every 1200 miles. Mine was under warranty at the time so GM did the repair - replaced the #2 ring and it solved the problem.
Old Mar 24, 2015 | 11:01 AM
Drumzy's Avatar
Drumzy
Thanks for the tip...going to try this!
Old Mar 24, 2015 | 11:29 AM
JR-01's Avatar
JR-01
Even though you might not have high mileage, this oil has additives that condition seals and a higher zinc content for these older cars. Worked for me.
To Excessive Oil use
