C5 Door window sweep installation
Old Apr 6, 2015 | 04:50 PM
Extra260's Avatar
Extra260
Default C5 Door window sweep installation
I'm away from my manuals. Can someone tell me what is involved in replacing the window sweeps?
Mark
Old Apr 6, 2015 | 04:53 PM
guido7834's Avatar
guido7834
Mark
The door panel has to be removed, then you can access the screws on the inside of the sweeps.
Old Apr 6, 2015 | 05:12 PM
Extra260's Avatar
Extra260
Thanks for the reply! I have to replace one window that is all scratched up so the panel has to come off anyway. So it sounds like a simple enough task to do!!!
Mark
Old Apr 6, 2015 | 06:30 PM
Mitch45's Avatar
Mitch45
I just replaced the driver side on mine . After you remove the screws you need to slide it towards the back , it is on pins ( don't remember how many ) .It is a tight fit and it might take a force to move . When I put the new one on it would not slide forward enough to get to top locating screw , ended up using a file to open up the slots a little to get into place .
Old Apr 6, 2015 | 07:40 PM
Extra260's Avatar
Extra260
Thanks for the added info. I'll keep that in mind when I change it out.
Mark
Old Apr 6, 2015 | 08:44 PM
Mickeyrx70's Avatar
Mickeyrx70
Just replaced mine on both sides along with new passenger door glass. The drivers side didn't want to slide all the way forward on install. Be careful not to force it -- the tabs will break off.
Old Mar 10, 2016 | 09:26 PM
DA1984VETTE's Avatar
DA1984VETTE
I know this is a year old thread, but I have a question on the installation of the window sweeps. I had to replace my drivers side mirror because it somehow got broken in my garage.. My wife thinks she did it so I let her believe it. Anyway I had to take the sweeps off and there was some sticky stuff like weatherstrip sealant on the paint. When I install them back on do I have to put the sealant back on or just install them without the sealant. My mirror I'm installing has to be repainted so I am getting both mirrors painted because of rock chips and the like and wife said go ahead..I think she feels guilty. I did try to tell her she didn't do it but she thinks she did hit it with something. So any help on whether I need the sealant or not would be helpful..Thanks..
Old Mar 10, 2016 | 09:39 PM
Mickeyrx70's Avatar
Mickeyrx70
Mine didn't have any kind of removable sealant. I would clean off what's there then just install the sweep.
Old Mar 10, 2016 | 10:00 PM
DA1984VETTE
That's kinda what I was thinking to Mickey. I all ready cleaned it off and just waiting on the mirrors to come back. Thanks for the quick response back...
Old Mar 11, 2016 | 01:48 PM
Mitch45's Avatar
Mitch45
I did not use sealant when I installed mine .
Old Apr 26, 2016 | 12:41 PM
jnpiii's Avatar
jnpiii
I also know this is an old post but I have a tip that I used when I installed both my sweeps the other day. It may help someone looking at old posts for solutions. Sliding the new sweeps into place is a chore! If you apply a little carwash or mild dishwashing soap to the top of the door and also the plastic studs on the back of the sweeps, they will slide into place much easier. Also there was no sealant on the new sweeps or the ones I pulled off.
To C5 Door window sweep installation
