[Z06] Torque Settings
Old Apr 7, 2015 | 08:54 AM
Vette_UK's Avatar
Vette_UK
Default Torque Settings
I'm getting ready to replace the sway bar bushings but need to know the torque settings for the brackets.
Anyone?
Old Apr 7, 2015 | 11:04 AM
dork's Avatar
dork
http://www.pfadtracing.com/blog/wp-c...structions.pdf
Will the specs on page 7 do?
Old Apr 7, 2015 | 11:12 AM
Vette_UK's Avatar
Vette_UK
Originally Posted by dork
Maybe - are the C5 and C6 that simliar underneath?
Thanks for posting.
Old Apr 7, 2015 | 11:26 AM
Last C5's Avatar
Last C5
41 ft lb - Just looked it up yesterday.
Old Apr 7, 2015 | 11:40 AM
Vette_UK's Avatar
Vette_UK
Sounds good, is that front and rear?
Old Apr 7, 2015 | 12:46 PM
dork's Avatar
dork
Thanks for posting.
I guess so, because the instructions say "1997 - Current" and include the C6 stats.
Old Apr 7, 2015 | 04:22 PM
Last C5's Avatar
Last C5
NO! Front only.
The upper rear clamp bolt spec is 49 ft lb (Use anti seize)
The lower rear clamp nut spec is 70 ft lb
Interestingly enough the online manual has the front clamp bolts torqued to 43 ft lbs. But 41 or 43 isn't going to make much difference.
Old Apr 7, 2015 | 04:53 PM
Vette_UK's Avatar
Vette_UK
Thanks for the responses.
My poly bushings should be here this week, so hopefully this weekend......
Old Apr 11, 2015 | 09:03 AM
Vette_UK's Avatar
Vette_UK
Bushings fitted. Thanks for your help.
To Torque Settings
