How 'Bout Them Round LED Taillights?
#41
Yep -- mine was the exact same way. Good luck on the harness.
#42
Supporting Vendor
I had the same issue. In my case, one side hyperflashed, the other did not. The hyperflash harness will fix it. To be honest I have constantly had issues with the harness I received from Radioflyer though. Something inside the harness was loose so I would get sporadic sticking of my turn signals, on and off. I would have to hit the bottom of my dash to jar it, but eventually I got tired of it so I ripped it open and fixed the loose connection myself. I don't know how long it will last though...
My two cents. Either way -- it's an easy fix. If you ordered the headlights and they were advertised as working without a hyperflash harness I would advise going to the distributor and asking for a harness shipped to you free of charge. The lights should work as advertised.
#44
Received 1,679 Likes
Love mine...
#45
Depending on you order date, you may still be covered under warranty. If not, it's possible there may be an issue with the flasher component. A replacement 3-prong LED flasher can be picked up from most auto parts stores to replace the faulty one if you're in a hurry to fix it.
#47
Received 3,888 Likes
2015 C5 of the Year Winner
I have to totally agree with you on this. I bought my halo LED's from JWMotoring and then I sent those off to RadioFlyer for his sequencing mod. I get lots of compliments and people want to know where I got them. I love the look of the lightly tinted halo tail lights.
#48
I like the LED lights, however I have been told there is not a set for my car, which has European rears.
If this is not correct, and they are available, I'd like to know where to get them from and if it's just a straight swap?
Regards
Regards
#49
Just got my halo led tails installed. What a huge upgrade over the stock units. Big thanks to George at Radioflyer for getting me the hyperflash relay. Now I'm ready for some clears on the front with some switchbacks.
