[Z06] replacing z shocks question
Old Apr 11, 2015 | 11:15 PM
LT1driver's Avatar
LT1driver
Default replacing z shocks question
any gotchas to look out for? will be doing this on jack stands so any suggestions would be great. how long a job is this on average.
Old Apr 12, 2015 | 01:39 AM
XotiK ZO6's Avatar
XotiK ZO6
It is pretty straight forward. Do a utube search and a search here.
Use the zip tie method on the front and check my post from a few months ago for the front bolt removal and install. It makes it a lot easier and you do not need the special tool to take the top nut off.
I would plan about 30 to 45 minutes per wheel.
Old Apr 12, 2015 | 02:57 PM
Paul 75 L82's Avatar
Paul 75 L82
Use the zip ties.
Old Apr 12, 2015 | 04:16 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
froggy47 and one other (starts with an e, epidicus or something like that) guy both have a good youtube video. I just did this job using those as a guide and the project was pretty straightforward. I found removing control arm bolts on the front, and tie rod ends on the rear were not necessary.
The previously mentioned zip tie method is the way to go. I did strip one of the front lower shock mount screws and it was $7 from GM, be careful!
Old Apr 12, 2015 | 08:38 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I used this write up I found. http://fuzzydiceracing.com/test.htm
Old Apr 13, 2015 | 07:33 PM
LT1driver's Avatar
LT1driver
thanks all.
To replacing z shocks question
