Oil change?
Old Apr 14, 2015 | 06:53 PM
DIABL0's Avatar
DIABL0
Default Oil change?
My vette sits all winter. I only put 500 miles on since last aprill when i changed it. Should i change the oil for the new season?
Old Apr 14, 2015 | 07:13 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
No !!!!!!!! is it in heated storage?????? if yes definitely no !!!!
Borntorun04/17's Avatar
Borntorun04/17
I put low mileage on my car each year and I change the oil at the end of October just before putting car in storage for winter. My thoughts are I would rather have car sitting for a while with fresh oil ,Then in spring I'm good to go. I been doing this sense I got my corvette five years ago. My car sits from Nov to middle end of April.
Old Apr 14, 2015 | 07:16 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
DIABL0's Avatar
DIABL0
No not heated.
Old Apr 14, 2015 | 07:46 PM
jackthelad's Avatar
jackthelad
Owners's manual says change oil when the DIC tells you to, but no more than a year between changes. On a low mileage car, I would change it before it goes into storage personally, so it goes in clean, as it were. I don't store mine, as I drive it to some extent all year around, but it gets less use in the winter - too many snow days.
I just pick an "oil change" day in late Fall and get all three vehicles done. The Subie turbo also gets a spring change - just as insurance, even though it probably will only have done 4k or so, I just am risk averse with turbo units, plus it has a stupidly small oil filter. Synthetic 5-30 for all of them, usually M1 high mileage; the Generac, the mowers, etc. get the same. Buy it when one of the parts chains has it on sale, or from Wallies.
Old Apr 14, 2015 | 07:48 PM
73Corvette's Avatar
73Corvette
You might check the oil containers you used for the expiration date...
Old Apr 14, 2015 | 07:50 PM
DIABL0's Avatar
DIABL0
Im just wondering because they put a miliage or date on the sticker an its past the date but the miliage is so low.
Old Apr 14, 2015 | 08:31 PM
ironranger's Avatar
ironranger
Get in the habit of changing it in the Fall each year before going into storage. It's cheap insurance and it removes any worry you might otherwise have!
Old Apr 14, 2015 | 09:50 PM
Corvette#2's Avatar
Corvette#2
Agreed, from what I've read on bitog, good synthetic oil with 500 miles on it isn't going bad just because it's been in use for a year. They have additives to specifically address that. But as they say, the manual recommends every year at least. I'm super obsessive and would follow the manual. But like I said, from reading stuff on bitog forum, the oil is fine to go another year.
Old Apr 14, 2015 | 11:10 PM
You can do as you please, but I follow the recommendation in the owner's manual. I do not put many miles on my car each year (perhaps 1-3K miles at most) but I still change mine each year before putting the car into storage.
Old Apr 14, 2015 | 11:14 PM
beboggled's Avatar
beboggled
Originally Posted by thisMSGgood4me
In my opinion, anyone who changes their oil after only 500 miles, even if it's been a year since the last oil change, is nuts. And wasteful. That oil is still perfectly fine.
My only complaint is that you're not driving it enough, if you've put only 500 miles on it in the last year. If that's the case, you might as well sell it and let someone else enjoy driving it.
I agree. Its wasteful to change so soon.
Old Apr 15, 2015 | 07:41 AM
strand rider's Avatar
strand rider
In my humble understanding, the owners manual has a time limit because once you run the oil, acids are promoted. Acids eat engine seals. Engine seals eat money. Oil change better than seal change.
I tend to follow the manufacturer's operators manual over internet advice.
I can't learn every machine I own, and certainly can't out engineer the recommendations of the original designers. I have worked with highly skilled engineers , and they always followed the books, or in rare cases, amended them , then followed the new instructions, to the letter. I don't see much advantage to winging it when you have instructions. Granted, owners manuals for cars are written for a low mechanical understanding, but they do ok.
Old Apr 15, 2015 | 10:03 AM
jhopper408's Avatar
jhopper408
I change mine in the spring.
Old Apr 15, 2015 | 10:20 AM
jjc508520's Avatar
jjc508520
Lots of good stuff here...
http://tech.corvettecentral.com/2011...d-performance/
Old Apr 15, 2015 | 10:32 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Same here.
Old Apr 15, 2015 | 11:37 AM
knewblewkorvette's Avatar
knewblewkorvette
To Oil change?
Old Apr 15, 2015 | 11:44 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Me too!
Old Apr 16, 2015 | 12:46 AM
6speedsteve's Avatar
6speedsteve
I only put about 600-800 a summer on mine & change it every 2 yrs, I give the oil to guys at work & they use it in their lawnmowers.
I think my DIC said 73% after these last 2 summers which was 1270 miles.
Old Apr 16, 2015 | 08:01 AM
strand rider
Just how much acid do you think there is in the oil after having driven for only 500 miles? You don't think the additive packages in modern synthetic oils are up to handling it?
Maybe I should start changing my oil after every long-distance weekend trip I come back from.
I did say it was a humble opinion, and you hit upon the flaw, unknown criteria for judgement. One could measure oil acidity with a PH strip, but being able to know the rate of seal damage over time with the Ph level at the test time would take more work than it would be worth.
I saw your point as I posted, but considered that a guy storing the car he hardly drives would probably be best served with fresh oil before storage. That way you wouldn't have to leave it to an almost new additive package. I figured a guy with a heated storage for a corvette driven infrequently wouldn't mind springing for new oil .
THis topic was covered By the late Mr. Bill, much more effectively. I couldn't remember if the acidity increases on its own after contamination or of it is mostly the amount of use. I seem to remember the contaminates overcame the additive package over time with even slight use, but did not want to post erroneous facts.
