[Z06] Check Engine LIght after Halltech T1
Old Aug 13, 2002 | 05:19 PM
My12secz06's Avatar
My12secz06
Default Check Engine LIght after Halltech T1
Its been a few days since I finished the intake install, put about 200 miles on the car, and today the Check Engine Light came on.. Can anyone please shed some light on this. I am enjoying the intake sooo much. Please respond.. Thanks
Allen
Old Aug 13, 2002 | 06:51 PM
My12secz06's Avatar
My12secz06
Default Re: Check Engine LIght after Halltech T1 (My12secz06)
Weird.. I got a U 1160 Code..
only code thrown... I reset it.. and my check engine light stayed on after starting the car.. weird..
So i parked it and will let sit a few minutes
anyone add light to this??
thanks again
Allen
Old Aug 13, 2002 | 07:24 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Hmm weird, here is what it is Loss of Communications with LDCM (LDCM Left Door Control module) maybe someone can elaborate! The only codes I ever got with the Halltech were P0171 Fuel Trim System Lean bank 1-B P0174 Fuel Trim System Lean bank 2-B :cheers:
[Modified by racer44, 4:25 PM 8/13/2002]
Old Aug 13, 2002 | 09:48 PM
My12secz06's Avatar
My12secz06
ahh i see why my light stayed on... went to the store to get some medicine, and did the check again, and say i did have a code left over it was one of the 0171, 0174... i believe it was the 0171 as i was so concerned to get rid of the check engine light hehe.
What do I do now that I am runnning lean
Intake was installed, it has the race filter, and the little breather filter on the tube, everything looks tight and was tight on install.
Allen
please respond, and thanks for the help earlier..
you mentioned you had them before, what was done to elminate? etc please help
Old Aug 13, 2002 | 10:06 PM
z06dailydriver's Avatar
z06dailydriver
After 7000 miles on my hALLTECH sIDEWINDER I got the P1074 code. The weird part is that it comes and goes, Check Engine light that is. Took it to the dealer and they said they could not find a problem. So here is what we are going to . When it goes on again, I will go straight to the dealer and they will plug in their diagnostic computer and we shall see whats going on.
We discussed what changed in the last few weeks and the only difference was that I started using 76 brand gas rather than my usual Hess. It is possible a different combustion rate in the gas could throw the o2 snesors off. So I am doing an experiment. I will report when I get some results.
In my case, the out of tolerance condition seems to be just on the edge. I would hate to give up my Sidewinder, but I also don't want to blow holes in the pistons,
Old Aug 13, 2002 | 11:20 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Your fuel trims are probably through the roof. The car is surely losing power at WOT high RPM.
Make sure the intake is making a tight seal. The T1 can fall off the MAF quite easily.
Make sure you have the elbow after the MAF installed correctly. The elbow's long radius section must go before the MAF. If you put the short radius in front of the MAF there is a gap created at the mouth of the MAF, which sends airflow in reversion. This is not listed in the instruction sheet.
Reset the code and pull the batt cable for a few minutes. If the code returns then either you still have an air leak or you need tuning.
Old Aug 14, 2002 | 07:17 AM
NastyC5's Avatar
NastyC5
I'm installing a T1 on my car Thursday. If I get codes I'll be :mad
Old Aug 14, 2002 | 09:52 AM
ZO6Les's Avatar
ZO6Les
Default Re: Check Engine LIght after Halltech T1 (rbartick)
I am with Ross on this. USUALLY a code means you have a leak and are getting unmetered air after the MAF causing a lean condition. Metered air will be adjusted by the ECM according to what the ECM see's.
Les
Old Aug 15, 2002 | 06:54 PM
BlueZ's Avatar
BlueZ
Default Re: Check Engine LIght after Halltech T1 (ZO6Les)
The T-1 is causing the lean conditions of up to 25% that is why the code came up. It may be a leak, but I have seen numerous posts about he same problem.
To Check Engine LIght after Halltech T1
