pop up headlight issue...
Old Apr 19, 2015 | 02:17 PM
98gorby's Avatar
98gorby
Default pop up headlight issue...
Very frustrating situation....
Was washing the car a few weeks back and after drying it......the right headlight popped up on its on......i turned it off.....minutes later it poppedback up on its own, this is with no keys in ignition.
I put keys in and now only left headlight motor works....right side is dead however lights work.
I checked fuses 3 and 4 all look good.
I ordered a brand new headlight motor and installed it today.....again headlight motor doesnt work....lights work no issues.
Im completley stumped.....checked fuses and replaced headlight motor still no luck.
Any further advice?
Old Apr 19, 2015 | 03:01 PM
98gorby's Avatar
98gorby
Maybe a mod can move this to tech forum for me.
Old Apr 19, 2015 | 04:28 PM
stu12dozen's Avatar
stu12dozen
Read #4 in the following post, Hope this helps.
https://www.corvetteforum.com/forums...t-pops-up.html
Old Apr 19, 2015 | 05:50 PM
Deneb's Avatar
Deneb
Check options for auto twilight on. Maybe a fiddle with this may help. Good luck.
Old Apr 19, 2015 | 07:29 PM
98gorby's Avatar
98gorby
Did some research and someone suggested the headlight relay module box.....i pulled it out and noticed some water damage....just ordered one off ebay for 89bucks.....se if that solves the issue.
Old Apr 19, 2015 | 10:51 PM
73Corvette's Avatar
73Corvette
Old Apr 20, 2015 | 09:34 AM
dadaroo's Avatar
dadaroo
That module is powered all the time for the motor circuits. So, if the control circuit wants to act up it will cause an unrequested actuation. Sounds like just the one side decided to have a hiccup. Each motor has it's own separate circuit in the module.
Old Apr 20, 2015 | 06:42 PM
2FAS4UU's Avatar
2FAS4UU
Poltergeist ???
To pop up headlight issue...
