Quick Oil Pressure Sender question...
Old Apr 19, 2015 | 04:47 PM
Bud Doggin's Avatar
Bud Doggin
Default Quick Oil Pressure Sender question...
Mine went this morning. 60 at idle and 80 when driving. My question is does it hurt anything to just leave it be for now. I'm thinking it doesn't but just wanted to check. Thanks!
Old Apr 19, 2015 | 04:55 PM
jackthelad's Avatar
jackthelad
Drove mine around for a month or so with the gauge pegged. Unless oil is leaking around the sensor, no problem.
Old Apr 19, 2015 | 04:56 PM
73Corvette's Avatar
73Corvette
won't hurt it to leak some either just keep a closer eye on your engine oil level... Heck we drove for years with only an idiot light, which only let you know that your out of oil.
Old Apr 19, 2015 | 05:05 PM
Bud Doggin's Avatar
Bud Doggin
Thanks!!! I just don't have the time or money to mess with it right now.
Old Apr 19, 2015 | 06:19 PM
Lee DeRaud's Avatar
Lee DeRaud
Originally Posted by thisMSGgood4me
It's not going to hurt anything to wait to replace it if you must, but check your oil level on a more frequent basis than you otherwise would since the gauge isn't working.
Ok, I'll bite: is there any reason not to trust the oil level sensor? It's a completely separate system from the oil pressure sensor.
Old Apr 19, 2015 | 06:31 PM
steelman63's Avatar
steelman63
You better make sure it is your sensor. When they go out they are usually pegged to the max all the time not 60 at idle and 80 when driving.
Old Apr 19, 2015 | 06:46 PM
Bud Doggin's Avatar
Bud Doggin
So what else could it be?
Old Apr 19, 2015 | 06:51 PM
steelman63's Avatar
steelman63
Spun cam bearing?
Old Apr 19, 2015 | 06:53 PM
Bud Doggin's Avatar
Bud Doggin
Spun cam bearing?
Really? Car runs perfect.
Old Apr 19, 2015 | 06:59 PM
steelman63's Avatar
steelman63
I don't know but I wouldn't keep driving it until I found out for sure. Seems like everybody is saying sure just keep driving it no problem...well there might be a problem just say'in.
Old Apr 19, 2015 | 07:27 PM
jackthelad's Avatar
jackthelad
That's exactly how mine was - startup it was about 50-60 then climbed to 80 and held there.
That's what I have always heard too. Might want to at least confirm that it is the sensor.
Old Apr 19, 2015 | 07:47 PM
Bud Doggin's Avatar
Bud Doggin
Well, I just checked the oil and it's about a quarter inch above the two humps... That may be the problem???
Old Apr 19, 2015 | 07:59 PM
1Willy1's Avatar
1Willy1
It seems like yours is still reading, when they fail they max out and no longer function at all.
If your oil level is higher then it should be then your oil pressure will be higher as well.
Old Apr 19, 2015 | 08:11 PM
Bud Doggin's Avatar
Bud Doggin
I would think it would have read high right after the oil change, not a hundred miles later... I don't know.
Old Apr 19, 2015 | 08:14 PM
Lee DeRaud's Avatar
Lee DeRaud
No, there's no reason not to trust it, but with the oil pressure sensor not functioning properly, it doesn't hurt to make visual inspections of the oil level. With your logic, then why would we ever check the oil level manually and instead put unquestioned reliance on the oil level sensor? Are we to trust the oil level sensor without question and never pull the dipstick except immediately following oil changes?
Quoting from Ronald Reagan, trust but verify. Good words to live by in my opinion.
Do you plumb up an external oil pressure gauge regularly to verify the internal oil pressure sensor?
Look, I agree it's a good idea (if perhaps somewhat redundant) to check the oil level manually on a regular basis. What I'm questioning is the rationale for checking it more often because a separate sensor system has gone fubar.
Old Apr 19, 2015 | 11:19 PM
jdvann's Avatar
jdvann
What does your digital oil pressure say? When my sensor went out, it pegged at 80 and the digital read 130 on the DIC.
To Quick Oil Pressure Sender question...
Old Apr 20, 2015 | 12:30 AM
tmatthews's Avatar
tmatthews
Originally Posted by thismsggood4me
no, because it's not nearly as easy as pulling the damn dipstick. And because both sensors have to do with the lubrication of the engine internals, if one sensor has gone fubar, maybe, just maybe, one should be a little more diligent checking on the proper functioning of the other sensor, visually making sure it hasn't malfunctioned as well. Is there some problem with that?
Old Apr 20, 2015 | 12:47 AM
Lee DeRaud's Avatar
Lee DeRaud
No, because it's not nearly as easy as pulling the damn dipstick. And because both sensors have to do with the lubrication of the engine internals, if one sensor has gone fubar, maybe, just maybe, one should be a little more diligent checking on the proper functioning of the other sensor, visually making sure it hasn't malfunctioned as well. Is there some problem with that?
No problem...beyond letting paranoia get in the way of common sense.
Old Apr 23, 2015 | 09:24 PM
Bud Doggin's Avatar
Bud Doggin
Follow up... I've been talking to the service manager at Corvette Mike, and I took it in today. He is sure it's the sensor, but does agree it's odd it's not pegged out. They take the intake off to replace... $$$... He said:"if it was my car, I would leave it alone". And that is what I'm going to do.
