Convertible trunk lid won't CLOSE.
Old Apr 20, 2015 | 03:55 AM
motomanvette's Avatar
motomanvette
Default Convertible trunk lid won't CLOSE.
New C5 owner here, tried a search to no avail. My 99' vert's trunk lid won't CLOSE. Must be getting jammed on the latch. First few times, I could hit the trunk release and it would "open" the latch, but now it seems stuck in the "closed" position. (the latch). Looks like I might get a dead battery with the lid open. Any thoughts?
Old Apr 20, 2015 | 06:43 AM
3sACROWD's Avatar
3sACROWD
Your battery should not go dead. After about 15 minutes, the lights will shut off.
Sounds like the latch is either gummed up or has a broken spring. Try putting a screw driver in the latch and pull while activating the switch. I'd then try some WD-40 to work it loose. If that frees it up, apply some graphite to the latch and you should be good to go.
Old Apr 20, 2015 | 08:22 AM
73Corvette's Avatar
73Corvette
I'd get some one to help me and have them "pop" the deck lid so I could observe what is happening... lubing sounds like a likely solution. Let us know how it goes...
Old Apr 20, 2015 | 10:15 AM
motomanvette
Took apart and the spring is either dislodged or broke. It kinda sticks up blocking the
striker from seating itself in the latch. New latch assembly is about $300. Any thoughts?
Old Apr 20, 2015 | 10:23 AM
73Corvette's Avatar
73Corvette
Originally Posted by motomanvette
Took apart and the spring is either dislodged or broke. It kinda sticks up.
spring or used latch from Marc and Vettenuts....
Old Apr 20, 2015 | 12:01 PM
motomanvette
Thanx, I'm new to the C5 forum, can you be more specific?
Old Apr 20, 2015 | 12:23 PM
3sACROWD's Avatar
3sACROWD
If you had a new spring, do you think you could replace it? If so, try a local hardware store (ACE Hardware) or a place like Fastenal or Mid-states bolts to see if you can get a spring. Another idea is to ask a local mechanic where they get their supplies. Not all auto parts chains (Autozone / Orielly's) carry the small stuff but the places that service mechanics do.
Consider watching for people parting out their cars on this forum in the "Parts for Sale or Trade" section or fleabay for a used latch.
Old Apr 20, 2015 | 03:22 PM
motomanvette
I can get a whole new latch assembly for $40. I assume a broken spring requires this?
To Convertible trunk lid won't CLOSE.
