[Z06] Oil pressure; what's normal?
Old Apr 22, 2015 | 07:56 AM
1996Z15's Avatar
1996Z15
Default Oil pressure; what's normal?
I was driving my 2002 Z06 over the weekend and I happened to look over at the oil pressure gauge. I noticed that it was all the way over to 80psi; I don't suppose that is normal.
Old Apr 22, 2015 | 08:57 AM
bjones7131's Avatar
bjones7131
No is isn't. Time to replace the oil sending unit behind the intake. Many many post on this and several ways to change it. Orileys has the best replacement according to the post I have seen, it is brass. Either pull intake and change or cut a hole in windshield cowl and replace or some on line you tube shows a guy doing it without pulling intake or cutting hole. You can barely see it and either way it is a PITA. Luckily I haven't had mine go out yet on my 2001 but I am on borrowed time. Some have bought the fitting and relocated it so it is easier next time. Good luck
Old Apr 22, 2015 | 10:27 AM
Fast Cop's Avatar
Fast Cop
When I did mine on my 00 vert I pulled the intake. Not a hard job and took about 2 hours.
Old Apr 22, 2015 | 10:41 AM
1996Z15's Avatar
1996Z15
Can I drive it like this until it can be fixed or no?
Old Apr 22, 2015 | 11:29 AM
Fast Cop's Avatar
Fast Cop
You can, it will not hurt anything. The only downfall is that if something happens to the engine that would cause a loss of oil pressure you would not know it.
To Oil pressure; what's normal?
