[Z06] How hot is too hot?
Old May 11, 2015 | 09:08 PM
Ohcat68's Avatar
Ohcat68
Default How hot is too hot?
Had my Z for about a year 43k on the clock, the previous owner (I'm #2) took great care of the vehicle, my concern is on hot days the car runs over 220* kinda freaks me out, I'm told they run hot but how hot is too hot?
Old May 11, 2015 | 09:26 PM
racebum's Avatar
racebum
should never get over 234, however, going to 230, then back down, repeat is common on a hot day in stop and go traffic. you can keep the AC on if you want to force the low speed fans into always on
pull your radiator and clean all the crap out of the fins if you haven't done so in the past 15-20k miles. it's basically a standard procedure for any c4/c5
Old May 11, 2015 | 09:30 PM
Ohcat68's Avatar
Ohcat68
Thanks!
Old May 12, 2015 | 11:12 AM
ERDOC's Avatar
ERDOC
Mine will run up to 238 on a hot summer's day in traffic. That's the highest number I've seen, but running it hard in the summer it will run in the 230s.
Old May 12, 2015 | 11:51 AM
Fast Cop's Avatar
Fast Cop
220 is fine. Shi* my 08 Silverado crew cab sits at 220 all day long. Closed system runs a little hotter and it's also for emissions.
Old May 12, 2015 | 11:54 AM
TXGS507's Avatar
TXGS507
Before adding my Dewitt's radiator, spal fans mine would reach 230-240 in the TX summer in traffic. Now it rarely sees 200....
Old May 12, 2015 | 12:04 PM
Breze84's Avatar
Breze84
I have a Dewitt's radiator as well, Last year my temp got up to 225 on a 60* day, I pulled in the garage climbed under the front of the car and seen that a little Walgreens bag got pulled up and was covering part of my radiator. Always check for obstructions....
Old May 12, 2015 | 12:06 PM
janky's Avatar
janky
I'd be more concerned with oil temp than coolant, that's a better indicator of heat pushing the engine towards failure. I stop running it hard @ 280, you can see the oil pressure has dropped significantly by that temp and I'm not keen to ruin any bearings.
I always leave the DIC on oil temp reading so I know both when the engine has warmed up and when the engine needs to cool down.
Old May 14, 2015 | 08:27 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
That sounds really hot to me.
Hottest I can remember mine getting was 217.
Sitting idling in 100+F, AC on, at the inspection station.
Normal cruising on the highway I'm 190-194. (Summer and Winter)
Try doing the following:
1.) Inspect your air deflector under the car. It MUST be angled so that air is forced up into the radiator. Over time it can get stuck (corrosion) and it may not be angled correctly. It may also be worn down and not have enough to scoop the air into the radiator. Make sure there is NO trash up in the radiator area as well.
2.) Follow my procedure on blowing out your radiator / condenser. You will not believe how much crap you will blow out. It also makes one hell of a mess in your garage. Be sure to have the windows in your car rolled UP !
See my web page www.ToqueZ06.com.
See section at the bottom "How to blow out your Radiator / A/C Condenser:"
3.) Pulling the radiator out to blow thru with water might be necessary, but try options #1 and #2 first.
Hope this helps
Toque
Old May 17, 2015 | 03:29 PM
401K Z06's Avatar
401K Z06
On hot summer track days, I'll commonly see 300F oil and 245F coolant. I change oil (Amsoil) every other track weekend and send sample to Blackstone for analysis, and results are normal after 10 years of this abuse.
Old May 18, 2015 | 09:17 AM
CorvetteJimZ06's Avatar
CorvetteJimZ06
I used to see 280s on the oil temp and 240s on the coolant when I tracked it. In 2007 I put in a Summit engine oil cooler in front of the radiator. When I track it, it now runs 210 on the oil when I keep the revs up on a 90F day and 200 on the coolant. In normal driving the oil temp stays around 185 now!
Old May 18, 2015 | 10:23 AM
dork's Avatar
dork
Man, am I glad to see those numbers! My car sat idle for about two weeks which is extremely rare for me--once in 2-1/2 years--so I started it up to let it run at idle temps and forgot about the car for almost 40 minutes... my wife came home and said, "why's the Vette running!?" I ran out and saw the gauges--232 coolant, 243 oil, and immediately took it to the freeway and drove it for 30 minutes to cool it down to "normal"--190 coolant / 196 oil (for that time of year), but it sure had me panicked since I'd never seen that oil temp before. All I could think was, "aluminum block and heads". That was 6 months ago, and I'm sure from the ~8,000 miles since then, that everything was fine after all.
To the OP, if you're really concerned about commute-traffic coolant temps, Southern Car Parts used to offer an aftermarket remote control fan switch w/ relay that would allow you to turn on the second fan at will. It is intended for less than 35mph. I can't find the link to it now, but you might inquire if it sounds like a viable alternative.
To How hot is too hot?
