Air cleaner cover
Old May 14, 2015 | 01:42 PM
jjc508520's Avatar
jjc508520
Default Air cleaner cover
Will this fit onto my stock '00 air cleaner?
http://www.gmpartsdirect.com/results...umber=19201295
I also looked at this - but it appears to have a smaller "notch"
http://www.corvettesalvage.com/index...oducts_id=1280
Old May 14, 2015 | 01:46 PM
R1 Rider's Avatar
R1 Rider
I'm thinking either one will work but I'm not positive, I just have my air filter zip tied in with no cover
Old May 14, 2015 | 02:02 PM
grantv's Avatar
grantv
As far as I can see in that picture the 2nd one is not from a Z06. The Z has the larger opening.
I'm guessing as to if the cover will fit your box. Just do a search here however for a complete used Z housing with cover maybe?
This for example; maybe the Z unit is available...
https://www.corvetteforum.com/forums...-99-coupe.html
Old May 14, 2015 | 02:32 PM
jjc508520's Avatar
jjc508520
You know the zip-tie solution sounds intriguing. Can water get past an oiled K&N?
Old May 14, 2015 | 02:46 PM
jjc508520's Avatar
jjc508520
There is another thread going about the zip-tie mod....
Old May 14, 2015 | 02:56 PM
R1 Rider's Avatar
R1 Rider
I've heard most have had good results with a K&N as far as water is concerned
Old May 14, 2015 | 10:29 PM
Yes, that first one will fit in the stock LS1 air breather and offers a little better air flow than the stock coupe/vert one.
To Air cleaner cover
