[Z06] Success With The Ranger Method
Old May 15, 2015 | 08:43 AM
Mac-427's Avatar
Mac-427
Default Success With The Ranger Method
I have a low mileage 2001 Z06, with 6,000 miles on the clock. I just replaced the Delco battery with an Optima Red Top, changed fluids, and replaced the 15 year old Goodyear tires with Bridgestones. I then, checked the clutch fluid and it looked pretty murky. I went to the grocery store, got a turkey baster, picked some Dot 3 brake fluid from O'Reilly Auto Parts, reviewed the Ranger method and got to work. I my case it only took two fluid changes in the reservoir, and a total of sixty pedal pumps to get things clean and clear. In the future, I plan just to change what's in the reservoir on a regular basis to keep things clean. I highly recommend the Ranger method and suggest that anyone with a six speed look at the clutch fluid before problems occur rather than after. If it hasn't been examined, it's my guess that the fluid will be pretty dirty rather than clean and clear. Thanks to the Forum for so much good info on clutch problems. As the doctors say, prevention is the best cure.
Old May 15, 2015 | 06:18 PM
bumble-z's Avatar
bumble-z
Good to hear & for you to pass the info on to others.
Strange how some just look at the outside of their cars and neglect the important things under the hood.
I guess outa sight..outa mind.
Old May 16, 2015 | 05:06 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Guess I'll just wait. Both sides should be showing up soon to debate the merit of the Ranger Method.
Old May 16, 2015 | 08:05 AM
FASTFATBOY's Avatar
FASTFATBOY
When I bought my 03 the clutch fluid had never been serviced. The clutch pedal would get soft after running the car through three gears.
I have flushed at least 7-8 times so far since Jan, fluid is always dirty. The clutch pedal issue has fixed itself, it operates normally now.
The seal has been damaged slightly from the lack of maintenance, until it fails I will keep flushing it, I only change the fluid now....takes about 5 minutes.
Old May 16, 2015 | 11:35 AM
Furiousone's Avatar
Furiousone
I need to do this soon...
Old May 16, 2015 | 04:09 PM
Trash's Avatar
Trash
You can eliminate the turkey baster or syringe and simply used 2-3 paper towels or a rag and soak/mop out the fluid. I've found that to be easier & quicker, not that the other method is difficult.
Old May 16, 2015 | 07:41 PM
halp's Avatar
halp
How do you get rid of the brake fluid soaked towels?
I use the baster and put the old fluid in a jar and then take it to the hazardous waste disposal every year with old oil, paint, and other stuff.
The towel method sounds easier, but I would not be comfortable putting the towels in the trash. Guess I could stuff them in a jar like I do the fluid.
Old May 16, 2015 | 11:38 PM
bobby777's Avatar
bobby777
Really? My neighbor dumps all his old fluids in the toilet-away they go-
Old May 17, 2015 | 02:10 AM
Trash's Avatar
Trash
I don't.
Old May 17, 2015 | 07:19 AM
laurent_zo6
Your neighbor is clueless. Does he smoke when he is in the bathroom?
Old May 17, 2015 | 10:06 AM
bobby777's Avatar
bobby777
He tells me this--all fluids contain chemicals and dumping into the toilet keeps the sewer lines clean--not sure if he smokes:He is a retired engineer with GE-
Old May 17, 2015 | 12:42 PM
MMVVETT's Avatar
MMVVETT
2nd Gear
Default Air in the System??
I just purchase a 2005 and had it for just a few weeks.
Than the clutch drop to the floor. It has been 25 years since i drove a standard and did not know about the clutch fluid. Lucky for me i was backing it in the garage then clutch droped. After reviewing the Ranger method i tried to clean the fluid but it is not working.
I think i got air int he system. Does any body know how to remove the air with taking it to the dealer?
thaanks'
Old May 17, 2015 | 03:49 PM
MMVVETT's Avatar
MMVVETT
2nd Gear
Default Air in the system
I just purchase a very low mileage 2005 and had it for just a few weeks.
Than the clutch drop to the floor. It has been 25 years since I drove a standard and did not know about the clutch fluid. Lucky for me I was backing the car in the garage then clutch dropped.
After reviewing the Ranger method I tried to replace the fluid but it is not working.
I think I got air in he system. Does anybody know how to remove the air without taking it to the dealer?
Old May 18, 2015 | 02:27 AM
laurent_zo6
Go to Youtube.com. Search for "Corvette flush bleed brake system by froggy"
Old May 18, 2015 | 11:09 AM
bluestreak63's Avatar
bluestreak63
You're in the C5 section. May want to post up in the C6 section...
Old May 18, 2015 | 04:53 PM
JBoyle997's Avatar
JBoyle997
I do the ranger method about once a month, my clutch fluid is never dirty, and no problems with clutch pedal sticking or acting funny. 70k headers/intake , stock clutch.
Old May 19, 2015 | 12:10 AM
racebum's Avatar
racebum
i do mine every 6 months. kind of like the dentist, cheaper and easier if you do it frequently
neglect it....clutch has to come out aka root canal
To Success With The Ranger Method
Old May 19, 2015 | 01:20 AM
momo20's Avatar
momo20
while the ranger method works, i find it very hard to believe you did this with just two fluid change's and six pumps of the pedal, its going to take more then that ..i have a remote bleeder on my S/C 03 Z06 and even with that it takes a good 3 to 4 reservoir fillings to completely flush the system..and you did this all with two and no speed bleeder...
Old May 19, 2015 | 08:50 AM
Mac-427's Avatar
Mac-427
Hi Momo, if you check my post, quoted above, you will see it was sixty pedal pumps, not six. By the way, I drove about 100 miles this weekend and checked the fluid in the reservoir afterward. It had changed color slightly but there were no particles in suspension. I drained the reservoir with my trusty turkey baster, wiped it out with a blue paper towel and replenished the fluid. I will continue to do so after I take the car out for a spin. My Z car is not a daily driver and still has only 6000 miles because it was a museum car. This makes it quite possible the original particle build up was light. I'll keep checking it to be sure.
Old Feb 2, 2017 | 06:56 PM
footballplaya3k's Avatar
footballplaya3k
Bump from the dead!
I bought a C5Z recently and came across the Ranger method. I looked at my clunch fluid and it was pitch black, looked like it had never been changed. Using the Ranger method it took 2 empties/fills and 60 pumps for it to be completely clear, same as the OP. I've done about 15 miles of city driving since then and it has remained clear. Do this!
