Headlight issues
Old May 20, 2015 | 10:42 PM
Sting99's Avatar
Sting99
Default Headlight issues
I notice that when I start the car in the mornings and I flip the lights on , no issues , run car for 20 min , turn off car , when I restart and turn on the lights they wont pop-up. I have to turn the switch on and off a few times to get them to pop-up... thinking its lightswitch on the column, has anyone had this issue, before I start replacing parts? any info would be greatly appreciated
Old May 20, 2015 | 10:56 PM
Russell Boulding's Avatar
Russell Boulding
Do the lights turn on but not pop up? Or do they not turn on and not pop up? There are tests that can be done to isolate an exact cause. But, in my experience (I own and operate a repair shop specializing in Cadillac and Corvette) if the lights come on but the doors don't open it is the headlight door motor module. If the lights fail to come on and fail to open it is the switch. There is of course the possibility of wiring issues, but that is less likely.
Old May 21, 2015 | 08:55 AM
dadaroo's Avatar
dadaroo
I'm with Russell on his assessment.
Old May 21, 2015 | 07:01 PM
Burkdog62's Avatar
Burkdog62
I had a similar issue with mine and it was the switch which failed. Try using the twilight function on the DIC once they don't pop open, that should confirm that your switching is going.
Old May 21, 2015 | 10:13 PM
Sting99's Avatar
Sting99
Russell, thanks for the helpful information , the lights do not pop-up or turn on , sometimes they pop-up but do not turn on? I have to flip the switch a couple of times then they eventually come on
Old May 22, 2015 | 10:58 AM
crob45's Avatar
crob45
6th Gear
I have a similar issue with my 2002. The headlight comes one but doesn't pop up every time. how do you diagnose power or gear issue?
Old May 22, 2015 | 11:12 AM
73Corvette's Avatar
73Corvette
Old May 22, 2015 | 11:13 AM
dadaroo's Avatar
dadaroo
A random issue is not easy. It could be the rubber stops are bad. Common issue. You could try replacing them first. Very easy and cheap to purchase. I have that info at home.
I can also provide you the connector views so you can see if they are getting voltage but then if it is random it is hard to catch it in the act.
Are you having an issue with both sides not coming up at the same time?
Could be the control module is the issue or the signal from the BCM is the issue.
Random issues suck to diagnosis.
Suggest you create a new Thread on your issue and then provide a link to it from here and we can help. Trying to address your issue in someone else's Thread is not the proper way.
Mr. Sam
Old May 24, 2015 | 08:44 PM
Russell Boulding
Certainly sounds like a switch issue. If you are comfortable with a multimeter I can help you be 100%. Just let me know
Old May 25, 2015 | 10:43 AM
Sting99's Avatar
Sting99
Russell , I will PM you .. thanks
To Headlight issues
