cd changer
Old May 26, 2015 | 01:15 PM
carhodge's Avatar
carhodge
Default cd changer
Are there any venders that fix fix cd changers,Mine stopped working after I changed batt.IT WAS WORKING UNTIL i Changed batt.I did reset button and it sees cd,won't see when I hit aux button.
Old May 26, 2015 | 01:41 PM
JR-01's Avatar
JR-01
Is your new battery fully charged? Try turning radio off, disconnect battery for a few seconds, reconnect and then turn radio on. Also try removing cartridge and then re insert. Changing a battery should not cause changer to go bad. Also pull codes. It might give you a clue to what happened.
Old May 26, 2015 | 08:36 PM
Doesn't make sense that a change of battery would cause the CD changer to quit working.
Old Jun 6, 2015 | 08:52 PM
JR-01's Avatar
JR-01
Did you get it working? We could use an update. Thanks.
To cd changer
