Key fob issues
Old May 28, 2015 | 04:41 AM
crazystevex's Avatar
crazystevex
Default Key fob issues
I have recently started having an odd issue with my key fob, everytime I train the fob to the car and leave it for any amount of time the fob unteaches itself from the car and stops working. I can teach it again and it works fine till I leave the car again for any given time.
The fob has a new battery and still does it, so...has anyone one else had this issue before? Maybe I just need to buy a new key fob.
Just more or less curious if it has happened to anyone else?
Old May 28, 2015 | 05:50 AM
65GGvert's Avatar
65GGvert
Don't know what year car you're working on (it matters), but it's a very common issue. Here's one of the many threads about fixing the issue:
http://www.google.com/url?sa=t&rct=j...93990622,d.aWw
Old May 28, 2015 | 09:58 AM
Check your fob per the link above and see if that is the problem. If your TPMS is working, the receiver in the car should be OK. If all else fails, replace the fob.
Old May 29, 2015 | 02:20 PM
crazystevex
Ah I see ill try what they have in that link thanks!, and its a 2000 btw with no other problems so it is probably that circuit board.
To Key fob issues
