Rear License Plate
Old May 28, 2015 | 04:26 PM
vette40509's Avatar
vette40509
Default Rear License Plate
Hello everyone,
Just moved up from a C4 to a C5 and am having trouble. Something I hope is simple. Removed the 4 screws on the rear license plate but the frame and plate do not come off. Is there something special I should be doing.
Also could use a front filler license cover in blue if anyone has one.
Thanks.
Malcolm
Old May 28, 2015 | 04:30 PM
1983JZR3W's Avatar
1983JZR3W
Look at the edge of the plate frame. There are four slots that you can insert a flat blade screwdriver into to pry it off.
Old May 28, 2015 | 07:01 PM
vette40509's Avatar
vette40509
OK, Thanks!
Old May 28, 2015 | 10:03 PM
Just a word of caution too - when you put the screwdriver blade in the slot, be gentle - those little tabs have a tendency to break easily if you use too much pressure.
Old May 28, 2015 | 10:13 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Front filler plates pop up on ebay all the time. Some used that are painted, hopefully to the color of your car, and some new, unpainted units.
To Rear License Plate
