Where Can I find Codes?
Old May 30, 2015 | 12:35 PM
Vette10R's Avatar
Vette10R
Default Where Can I find Codes?
I pulled the codes from my DIC and there are several of them. I wrote them all down and im wondering where I can find what each codes means?
Old May 30, 2015 | 12:51 PM
dmarkshark's Avatar
dmarkshark
You can always Google them.
Old May 30, 2015 | 12:53 PM
This might help you out. Not sure what year car you have so I just added all the files I have on trouble codes. Will add more in the next post.
You could also post the codes up here and I'd bet someone on here can tell you exactly what they refer to.
Old May 30, 2015 | 12:55 PM
Here's more:
File Type: doc
File Type: doc
File Type: doc
File Type: doc
Old May 30, 2015 | 01:12 PM
Vette10R's Avatar
Vette10R
Thanks Vetteman Jack!!
Its a 1999 by the way...
10-PCM P0420 H
P0430 H C
P1416 H C
28-TCS C1243 H
58-SDM B1001 H
A1-RDCM B2285 H
B0-RFA U1096 H
U1064 H
U1016 H
C2105 H C
C2110 H C
C2115 H C
Old May 30, 2015 | 03:50 PM
Vette10R's Avatar
Vette10R
Originally Posted by 8VETTE7
Suggest that you start by checking the battery to insure it is fully charged. A good battery at full charge will measure 12.7 to 12.9 volts or more when measured across the battery posts using a digital multi meter and with the neg battery cable disconnected. DO NOT use the dash gauge readings to determine the state of health of the battery. They show the state of health of the charging system. With engine running they sort of show the output voltage of the alternator. Sort of because the gauges are down stream of the ignition switch and the C5 ignition switch is well known for pitted and carboned contact surfaces that reduce the gauge readings. With engine off and key on there are many electrical circuits in the C5 loading the battery so that reading is all but worthless..
Once you have a known good battery at full charge, clear all the codes that you have and then take the car for a nice ride. When you return pull the codes again BEFORE you shut off the engine. To pull codes with the engine running you MUST first use the reset button to clear all messages in the DIC. Then pull codes as normal.
Codes that have returned are the ones you need to be concerned with.
If you need help with them post then in this thread.
Thanks for the reply, Ill take it for a ride today and see if there are any new codes. I purchased the battery spring 2014 its an Optima Red Top. Hopefully its not bad already!
Old May 30, 2015 | 08:47 PM
Vette10R's Avatar
Vette10R
Ok cleared everything and went for a good ride and these are the codes that came back...
P0420
P0430
C2105
C2110
C2115
Thoughts?
Vette10R's Avatar
Vette10R
FYI I have no cats so that's the first 2 I'm assuming...
To Where Can I find Codes?
