my high speed fans will come on via the temp sensor at 225, but if you search around, i believe someone here on the forum sells a kit that that allows you to kick your high speed fan on via a small keyfob remote with the push of a button and no need to activate the a/c if you are more comfortable with something like that.
my 04 commemorative edition convertible will run oil pressure of about 60 at start up but will eventually settle in the 40psi range under load once warm.
