I finally got the factory radio reception fixed on my 01 coupe. Should have tried this fix in the beginning.
I installed it on the windshield where the factory antenna is. It attaches with double sided tape and connects with a 12 v power wire and a ground. Super easy, quick and efficient fix.
I added a wire to the chassis ground in the passenger seating area. I attached a wire from there to a ground distribution block I installed in the right front kick panel. Power was from fuse location #22 in passenger footwell.
