3 trouble codes?
Old Jun 1, 2015 | 08:29 PM
R1 Rider's Avatar
R1 Rider
Default 3 trouble codes?
Just checked mine for codes, I got
U1096 lost communication with IPC
U1064 lost communication with BCM
U1016 lost communication with PCM
Soooo, what's this mean?
Old Jun 1, 2015 | 08:34 PM
R1 Rider's Avatar
R1 Rider
I just remembered I had my battery disconnected for about an hour two or three weeks ago, could that have tripped the codes?
Old Jun 1, 2015 | 08:59 PM
Bill Vett's Avatar
Bill Vett
There's your answer to the loss of com. codes. Just clear them and you're good to go.
Old Jun 1, 2015 | 09:25 PM
R1 Rider's Avatar
R1 Rider
Thank ya sir, after I cleared the codes, I started it up to see if any returned, they did not! But figured out my battery is weak, got it charging now but it's 5 years old, may be time for one
Old Jun 1, 2015 | 09:26 PM
striper's Avatar
striper
My car always shows those faults. After 12 years I have concluded they are of no consequence and have never given a moment of problems. Ignore them.
Old Jun 1, 2015 | 10:18 PM
Bill Vett's Avatar
Bill Vett
If your car is not a daily driver invest in a battery tender. I have had a battery last 8 years in my car keeping it on a tender between drives.
Old Jun 1, 2015 | 10:53 PM
R1 Rider's Avatar
R1 Rider
I think I'll get one
Old Jun 2, 2015 | 10:56 AM
Bill Vett's Avatar
Bill Vett
Here's a little trick, set you DIC to average mpg in the fuel section. If you get into the car to drive it and it has defaulted to the cars mileage your battery is low. As the battery begins to loose its charge the computer will begin to throw away info it doesn't need to save power.
Old Jun 2, 2015 | 11:19 AM
R1 Rider's Avatar
R1 Rider
I'll try that , thanks!
To 3 trouble codes?
