Another mystery
Old Jun 5, 2015 | 08:39 AM
SeattleVette's Avatar
SeattleVette
Default Another mystery
My C5 has 6400 miles on it, so it's super clean. Anyway, I just bought a lift so I can finally get access to the underside of the car without having to put it on ramps and suck in my gut. While admiring the near perfect underside I noticed something interesting on the gray figerglass panel that is just above the muffler tips. There are two pieces of back "something" about 2" x 2" square (about 1/8") thick that are stuck to this gray panel. They are high enough up that you can't normally see them and have a plastic film over each one. They seem to have some tackiness when you peel the film back. At first I thought this was some sort of double sided tape to mount an exhaust plate, but one of them is way out of the way and not near the center of the exhaust tips. I'm wondering if this was maybe some sort of way that GM attached the build sheet as it rolled through the factory and they were supposed to be peeled off at the end.
Not really sure, but it does seem odd. Regards,
OJ
Old Jun 5, 2015 | 08:46 AM
Macleod52's Avatar
Macleod52
I would assume it's the tape to adhere the exhaust plate. Maybe the previous owner screwed up with placing the tape and didn't finish the job or maybe just decided not to install it.
Old Jun 5, 2015 | 09:17 AM
73Corvette's Avatar
73Corvette
Pic?
Old Jun 5, 2015 | 11:24 PM
Just checked my car and it has the same two pieces on it. So, I doubt it is anything to do with the previous owner or any exhaust plate error. Must be something from the factory but exactly what I have no clue.
Old Jun 6, 2015 | 07:34 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The last time I was under my car, I seemed to recall the same thing...
Old Jun 6, 2015 | 08:00 AM
Black 03 Z06's Avatar
Black 03 Z06
Factory Option for CCW. Did not sell well.
Old Jun 6, 2015 | 11:16 AM
DRAFT1's Avatar
DRAFT1
I get it!
To Another mystery
